Hi
I have noticed a strange behavior on VRM recently on one of my sites. This is a purely single-phase, on-grid installation, with loads on both the input and output of the inverter (MultiPlus-II 10000), a Victron MPPT and a Solis PV inverter on AC-Out 2 monitored by an energy meter. This all displays correctly on VRM, and used to do so always. Recently however I have noticed that sometimes at random - I haven’t been able to pick up a trend as to what triggers this - VRM will spontaneously start showing a bunch of extra data that the system does not have. Specifically, on all three the AC Loads, Essential Loads and PV Inverter cards, it will start showing L2 and L3 - all NaN because there is no second and third phase to report data of (both the grid meter and PV Inverter meter are single phase meters). Interestingly it does not add L2 and L3 on the Grid card. In addition to that, it will also add a phantom PV Inverter on the grid-side of the inverter, also in three phases, with all three displaying NaN. In addition to that, it also exposes the Time to go datapoint on the Battery card - again NaN because the battery’s BMS does not report that value.
This is always fixable by refreshing the page, but it does eventually come back. Sometimes it spontaneously resolves on its own. I have rebooted the Cerbo, but the behavior persists. Lastly, I have not noticed this on my other two sites, also single-phase.
I attach two screenshots: one showing the correct behavior, the other showing the bug.
