VRM dashboard: let the Meteo tile show wind speed (and other values), not only irradiance
Hi Victron team,
The VRM dashboard tile for a Meteo device currently only shows Irradiance (W/m²).
On my boat there is no irradiance sensor, but I do have wind data. I publish it as a Meteo device using the Node-RED virtual device (node-red-contrib-victron), with the /WindSpeed path in m/s.
What works: - The GX device shows “Wind speed 4.2 m/s” under Settings > Devices > Wind. - The value is available in VRM Advanced, where I can graph it.
What doesn’t: - On the VRM dashboard the tile only shows “0 W/m²” (irradiance), even though wind speed is being reported. The wind speed is not visible anywhere on the dashboard.
Request: Please allow the Meteo tile on the dashboard to show other values than irradiance. Any of these would solve it: 1. Let the user choose which value is shown as the main value in the tile (irradiance, wind speed, wind direction, external temperature, cell temperature). 2. Show all values that the device reports, similar to the temperature tile (main value plus smaller secondary values / expandable section). 3. At minimum, hide irradiance when the device does not report it, and show wind speed instead.
Use case: boats and other off-grid installations with a wind instrument (NMEA 2000 via Signal K on the GX device) that want a quick overview of wind speed on the VRM dashboard without opening Advanced. The same would also help users of physical Meteo sensors that report wind.
Setup: Cerbo GX, Venus OS Large [3.85], node-red-contrib-victron [version], virtual device type Meteo, VRM dashboard.
Just to clarify: I am already sending WindSpeed (m/s) to a virtual Meteo device, and it shows correctly on the GX device (Settings > Devices > Wind: Wind speed 4.2 m/s) and as a graph in VRM Advanced.
The problem is the VRM dashboard: the Meteo tile only shows Irradiance (0 W/m² in my case, since I have no irradiance sensor), and the wind speed is not visible there.
A virtual temperature sensor does not help, as its tile has no field for wind speed.
Could the dashboard tile show wind speed when the device reports it, or at least not show irradiance when there is no irradiance value?
Screenshots attached: GX device page showing wind speed, and the VRM dashboard tile showing only 0 W/m². Thanks!
(Claude supported with text but could not figure out a solution for this)
Hi, as far as I am aware this integration is solely intended for the victron solarsense 750, not for the purpose you intend it for.
Nodered is often ahead of VRM, but we don’t have any visibility if this is on the VRM roadmap or not.
They can have different priorities.
But, you never know.
Thanks Nick, understood that it was designed around the SolarSense 750.
Still, the Meteo device already has a WindSpeed path that is shown on the GX device and in the VRM Advanced graph, so it seems there is room for improvement on the VRM dashboard: the tile could show wind speed when the device reports it (or at least not show 0 W/m² when there is no irradiance value).
While looking at this I also noticed a colour mix-up in the Advanced graph for the Meteorological Sensor (see attached picture): - “Solar Irradiance (W/m²)” is blue and “Wind speed (m/s)” is orange, both in the legend and as axes (left axis blue, right axis orange), and the wind speed line is orange. - But the readout below the graph (“Wind speed 5.30 m/s”) is drawn in the blue irradiance colour, not orange. It looks like the readout is tied to the irradiance series.
This seems related to an older report, where wind speed under the graph was not shown in the right colour and disappeared when irradiance was hidden: BUG: Meteorological Sensor VRM graph issues
Setup: Cerbo GX, virtual Meteo device from Node-RED, VRM Advanced.
Fair enough, but they are different development tracks and they rarely align, especially if you lean towards betas or newer functionality. There are particular gaps in virtual devices, a couple of posts on this, some will correct with time, others aren’t on the roadmap.
There tends to be a broader ability to chart and control from within nodered and its dashboards, intended for local (console) use, not all of it will pass through to VRM. Sadly we won’t know until @Barbara announces it on the internal groups then as one of her regular updates on the community.
(That is also something else to check, if betavrm behaves any differently).
The incorrect legend does seem like a bug.
