Hi Victron team,
I would like to report a touch interaction issue in the VRM Controls panel with Node-RED virtual switches configured as Numeric input.
My installation has many virtual switches of different types, so the panel requires vertical scrolling. Scrolling with a finger works normally when the gesture starts elsewhere in the panel. However, if I start the same scrolling gesture directly on the + or − button of a Numeric input control, the panel does not scroll. Instead, the button is activated and the numeric value changes.
The same incorrect behavior occurs both in the VRM app and when accessing VRM through a web browser on my phone.
Steps to reproduce
Create a virtual switch in Node-RED and configure it as Numeric input.
Have enough switches in the VRM Controls panel to make the list vertically scrollable.
Open the panel in the VRM app or a web browser on a smartphone.
Place a finger directly on the Numeric input control’s + button and drag vertically, intending to scroll the list.
Repeat with the − button.
Actual behavior
The panel does not scroll when the gesture starts on either button. Instead, + increases the value or − decreases it, even though the intended action is a swipe rather than a tap.
The same scrolling gesture works when started elsewhere in the panel.
Expected behavior
A vertical swipe should scroll the panel, including when the initial touch falls on a + or − button. Once the interaction is recognized as a scrolling gesture, it should not change the numeric value. A deliberate tap should still operate the button normally.
Hardware, firmware and client device
Current GX device: Cerbo GX MK3
Current firmware: Venus OS v3.81
Previous GX device: original Cerbo GX, on which I also observed the same issue
Earlier affected firmware: Venus OS v3.80 and v3.7x versions
Smartphone: Samsung Galaxy S26 Ultra
Mobile operating system: Android
Affected interfaces: both the VRM app and VRM in a web browser, with the same behavior on this phone
Impact
This makes a long list of switches difficult to navigate by touch, because attempting to scroll can unintentionally change a control value. These changes can sometimes go unnoticed while scrolling, significantly affecting system operation and causing unexpected behavior without the user realizing that a setting has been changed.
Could you please investigate the touch gesture handling for the Numeric input + / − buttons in the VRM Controls panel?
