I have renamed one of the built in relays in the Cerbo GX to a custom name within the Venus OS. In the beta VRM instance, the switch shows up as GX Relay 1 and not the custom name. Have some custom switches created in Node Red and they appear OK.
Thanks. I guess a workaround for the time being would be to turn off the local switch in Venus and assign the relay to virtual switch in Node-Red so it can appear with a custom name.
I see the same issue in firmware 3.73 with the large installation both node-red and signalk.
It is ok on the cerbo gx display but in VRM it will show up with relay one name “GX Internr relä 1”
Tried to reload the vrm page and tried to rename the relay, no difference.
I have the same firmware as you, and the issue is only with relay 1. Can I ask does your controls load? it’s the button in VRM to the right of switches.
