Voltage drop MPPT 100 30
Hello, i recently did my first install of a 300W solar panel in my camper. Linked to a 100 30 MPPT, 300AH lifepo4. Everything went well at first test, even pulling stable 350w. Now I routed the 4mm2 cable through the roof, sealed the entry gland and grommet and connected everything. Now there’s a big voltage drop issue. I turn it on and in full sun it reaches max 220W for a few seconds at 36v and then dips down to as low as 100w and 15v. I measured voltage with multimeter before it reaches the breaker and it confirms the same. The drop only happens when it’s connected to the MPPT. I bypassed the breaker routing directly into the (new) MPPT and removing ferrules incase it was poorly crimped. But no difference.
I put the outside connection in a tight spot I noticed one of the MC4 connectors wasn’t fully plugged in, about 1 mm before it clicked, it sat like this for an afternoon. So I suspect this might have caused an arc that burned the plastic of the mc4 and causes the voltage drop. Visually the inside of the MC4 connectors don’t show any signs of burning. I didn’t screw them apart but just looked into the pins.
Another suspect is that the cable was damaged during install, I bent it and shallow scratches on the insulation. But the bends were not so strong that I feel it could’ve damaged the wire strands. But it could explain the brief 220w followed by voltage drop. If the wire is damaged and the heat increases so does resistance.
I don’t have new MC4 connectors nor a crimping tool. I do have a spare short section of the PV cable with it’s MC4 connectors on it, could I replace the possible damaged ones with this by bud connecting. I also have another solar panel like it which I could Before I rip apart the wiring and start replacing MC4 connectors. Could there be any other cause of the problem? Thank you in advance!
Even under ideal panel angle to the sun that is only possible as long as the panel is cold. You will very very rarely see a power output above the rated figure under real world use.
That the panel voltage drops under load is also normal.
How long did you let the MPPT run for? I would also expect a bit more power from a 300W panel even when mounted flat, but not much more than the 200W you see briefly.
Which panel exactly are you using?
I was surprised too. And in fact it was around 25 degree Celcius and not ful sun when i saw 335. I estimated that it could reach 350 in full sun. Could it be a problem? Was reaching 38v before.
I let the MPPT run for a while and sometimes its stabilizing around 200w. But surely sudden drops of 15V shouldn’t be normal right?
The SoC is high at 95%, charging Bulk. At some point charge rate should slowly taper down but not drop 15v right?
Possible cause found for MPPT voltage collapse — sanity check?
300W panel (this IV curve), 100/30 MPPT, 4mm² cable. Was seeing power spike briefly to ~220W at 36V, then collapse to ~100W at 15V within seconds, only when connected to the MPPT.
I capped max charge current to 20A and the problem stopped completely.
My theory: at lower irradiance (e.g. 600W/m²), the panel’s max current is only ~5.8A (flat part of the IV curve). If the MPPT’s control loop tries to pull more current than the panel can supply at that moment, the operating point gets pushed past the curve’s “knee” onto the steep falling edge, where voltage collapses rapidly for almost no extra current. Capping the max charge current keeps the MPPT from overshooting past that knee, so it settles back on the flat/plateau part of the curve instead.
Does this match how you’d expect an MPPT to behave when its current target exceeds what the panel can deliver at a given irradiance? Or is there a different mechanism (e.g. MPPT algorithm quirk, sweep/rescan overshoot) that better explains a spike-then-collapse pattern like this? Or is the likely cause still a damaged
connection?
