# Virtuel Switch/ Droptown - Comportement lors des redémarrage système / System restart behavior
**URL:** <https://community.victronenergy.com/t/virtuel-switch-droptown-comportement-lors-des-redemarrage-systeme-system-restart-behavior/59860>\
**Category:** Node-RED\
**Tags:** virtual\_switch, cerbo-gx\
**Created:** [29 June 2026 11:41 UTC](https://community.victronenergy.com/t/virtuel-switch-droptown-comportement-lors-des-redemarrage-systeme-system-restart-behavior/59860 "2026-06-29T11:41:45Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![deon.korb](https://avatars.discourse-cdn.com/v4/letter/d/8c91f0/32.png) [@deon.korb](https://community.victronenergy.com/u/deon.korb)\
**Post date:** [29 June 2026 11:44 UTC](https://community.victronenergy.com/t/virtuel-switch-droptown-comportement-lors-des-redemarrage-systeme-system-restart-behavior/59860/2 "2026-06-29T11:44:47Z")
</div>
I did mention it here: [[SOLVED] Directory with Node-Red write access in a GX device for storing parameters - #6 by deon.korb](https://community.victronenergy.com/t/solved-directory-with-node-red-write-access-in-a-gx-device-for-storing-parameters/59474/6)
Probably a bug, and not sure anyone is fixing it
_[View the full topic](https://community.victronenergy.com/t/virtuel-switch-droptown-comportement-lors-des-redemarrage-systeme-system-restart-behavior/59860)._
