VictronConnect & VE.Bus communications on iOS/iPadOS
Little off topic question, but anyway… will VE.Bus interfacing (conf and updates) be enabled in VictronConnect running on Apple devices like USB-C equipped iPads and iPhones?
Is there a restriction imposed by Apple or it has just not been implemented?
Thanks
Moved to a dedicated topic. We’re trying to keep to the regime of not commenting on change logs and rather opening new, or adding to existing topics. Thanks.
Please edit the subject as necessary.
Thanks for all the constructive feedback!
Ok… thanks
Hi @peter , doing that is really difficult to achieve with Apple. If I remember correctly (its been a while), then can be done, but too much effort, compared to other improvements that can be done in such amount of time.
Thank you for your response @mpvader. I will not place my hopes too high then.
However, please keep this task somewhere near the very bottom of your to-do list. It would be nice to only need to bring an iPad with MK3 adapter to diagnose and fix problems at the site one day in the future (without the need to bring computer)
Yes will do. Note that it already works on Android devices!
