Hi @Slowmo ,
We’ll fix both the bug and think of a better UI to prevent the swiping interaction conflict. Thank you for the feedback!
Hi @Slowmo ,
Nice, the tap-through sheets look good. Question: is this only for installations with a GX on VRM, or does a Bluetooth-only system (SmartShunt plus MPPT on a VE.Smart network, no GX) get a system view too? Many van and small-boat setups have no GX.
Hi @merten ,
this same design will also be worked on for ‘bluetooth / local only’ systems indeed ![]()
Hi Barbara not sure if this is a new bug.
If one uses the “Next 2 days” quick select, then you manually adjust the time frame to reflect 3 days of time, when you hit Apply custom range it goes back to the 2 day selection. This seems to happen for any custom duration of three days. Two days and 4+ days seems to work as expected:
Select 3 day period:
Resets to two days:
Hi there,
No, this is new, and that is quite specific
We’ll make sure to fix it this week still!
Hi Brucey,
This is expected: the battery SOC forecast only is available around 3 PM each day, when the prices for tomorrow are available and DESS starts scheduling for it.
