Advice please if you will? So, I just had to change the wire strain plate on my Orion xs. I stripped a screw and had to drill it out and left it in until I sourced a new plate. I left the charger in-situ and stupidly didn’t disconnect power. It’s in an awkward cupboard. As I removed the broken plate away from the unit the screwdriver fell and hit the cable(s) at the terminals and there was a bit of a spark.
The app showed no obvious faults. I drove and monitored it moved through it’s cycle of absorption, bulk, float and storage. It was quick to move through as the battery was almost full with the solar having been doing its thing.
No appliances or lights etc were running in the camper when I first drove, so the current showed 0A and power 0W. I put the fridge on and got the readings in the image below.
The solar output showed the following (overcast and starting to rain):
I presume no damage has been done? Have I been lucky? I did feel the fuses and the unit after a 20 minute drive and there was no heat.
Anything I should check for, physically or on the app, or does this look OK?
Thank you in advance for any help.
