Victron system does not prevent grid feed-in by SolarEdge inverter
I have been trying to automatically prevent grid feed-in by my SolarEdge SE3680H inverter using Modbus commands sent by my Cerbo, but it just doesn’t work. Hope someone can point me in the right direction.
My setup:
  • Three-phase system with Victron MPII 5kVA inverters.
  • Four Pylontech US5000 batteries, 19,2kWh in total.
  • SolarEdge SE3680H inverter (firmware version 3.2543.0) on AC-Out L1 with LCD screen (4.320Wp PV in total).
  • Victron 250/60 MPPT (2.250Wp PV in total).
DESS functionality works fine. Once the batteries are fully charged, excess PV power from my SolarEdge inverter is fed into the grid. Preventing this with the Cerbo ESS dynamic power limiting function does not work. I noticed that the DESS does not consider/use negative electricity prices when charging my batteries, it only uses PV power. Maybe this is because the Cerbo doesn’t succeed in throttling my SolarEdge inverter.
I want my Cerbo to send Modbus commands to my SolarEdge, goal is to throttle or even shut down the inverter to prevent grid feed-in. According to several sources I found on the internet, this should be possible. However I also noticed that many people run into similar problems as I do. To prevent dependencies I prefer to realise this approach with standard Victron/SolarEdge functionality only, so without using Node-RED or Home Assistant.
As far as I know, the configuration settings of both my Cerbo and my SolarEdge inverter are correct (enabled dynamic power limiting, AC and DC-coupled PV feed-in excess, RS485-1 config, Modbus port 502, unit ID 126 etc).
My original SE3680H firmware (3.2537) apparently contains a bug that causes it to ignore Modbus control commands from my Cerbo. The good folks at SolarEdge kindly upgraded my firmware to 3.2543 (not publicly available), but unfortunately that didn’t help.
When downloading the configuration files using the VRM Portal (Device list => Remote VEConfigure => Download), I noticed that both my SolarEdge inverter and my MPPT do stop feeding PV energy towards my system. Based on what I have researched so far, my understanding is that the mechanism used here is different than the one I need to throttle my PV inverter.
Currently DESS will only restrict feedin if sell-prices are negative.
To verify if general AC throttling would work at all, you can disable AC and DC feedin in the ess settings when your battery is full and load is low. This then should bring the ac inverter down to consumption, if working correctly.
That’s indeed what I tried, but it doesn’t work. My Cerbo appears to completely ignore the AC and DC-coupled PV - feed in excess settings.
I am quite new to Node-RED, but I tried to monitor the Modbus traffic between my Cerbo and my SolarEdge inverter. Couldn’t see any throttling messages going to the SE, but I’m not sure if I did it correctly.
BTW: didn’t know about the negative prices, good to know. However, we had a couple of days with negative prices in April and it didn’t work then either.
Are you usig the solar 3dge meter at all?
Thank you. I don’t use the SE power meter, I’m not convinced that I need it since all the required information for the throttling decisions is already available in the Cerbo. Reading different stories about this, some state that you do need the meter others state that you don’t. I do have a Victron ET112 meter, but my understanding is that you can not use this meter for the PV production figures and use Modbus to send control commands. Don’t know why that is. So that’s why I get my PV production readings via Modbus TCP.
I’m aware that the Victron SE integration document states that you need the SE meter, but that seems to use an alternative method (Automatic Power Control/APC). It also refers to ‘alternative power sources’ like generators which I don’t have/need. My conclusion therefore is that this is not exactly what I need, however most sites refer to the manual. BTW: I included this information in my original post, but that was kicked off the forum because it was too long :slight_smile:
Read the article you sent. I also did everything mentioned in Solution 4 (Matthijs’ request for help with the new release).
Can you verify the devicepage is showing this Dynamic Power Limit Path?
If so, what is its value during regular operation and the moment throttling should kick in?
You then could try to set this path from a nodered script as well, and see if instructions are send out.
(/Ac/PowerLimit)
Then we could see, if the gx is not attempting to throttle, or if it does, but the inverter not react.
It was not a need per say. I think the use of it changes how the system is controlled and what paths are used. Which is why i asked.
This is what I see in my system:
The Dynamic power limit of 3680 is the maximum power that my inverter can supply, so that seems ok. Have not seen any other value here than 3680.
Yes, that was also my conclusion. It’s a bit confusing to be honest. Why would a SE power meter be needed if all the required information is already available in the Cerbo ?
Will try to create this Node-RED flow, thanks.
The control system of the inverter, sometimes new paths open up to modbus with meters added.
Seeing information and being able to interact or control are two different things. Node red may be the way for now.
@dognose: can you provide some additional details for this Node-RED flow ? :slight_smile: Not sure how to create it myself, I’m quite new to Node-RED.
Finally got my Solaredge SE3680H inverter to react to throttling commands, very happy with that. I found it more complicated than necessary because of the different methods described on fora to address this topic. That Solaredge has the same product number (SE3680H) for two different inverter types (with and without LCD display) also didn’t help, neither did the fact that there are some Modbus bugs in the most commonly used firmware version for my inverter. I found it easy to get lost in the SE3680H menu options, mainly because there are so many different FW versions which each appear to have different names for the same menu item. As described earlier in this topic, I ended up using version 3.2543 of the SE3680H firmware.
Anyway, the solution was to use Solaredge Power Control ‘Reactive Power Control’ feature and set this to RRCR. Important to double-check all the other menu options that apply to power control in the inverter, as some might conflict with the RRCR feature.
As @dognose pointed out, the Victron DESS only restricts feed-in if sell prices are negative. Therefore I haven’t seen throttling by the DESS yet. However I made a Node-Red flow that succesfully throttles the Solaredge inverter so the functionality works fine.
