VICTRON SW TEAM - VE Configure 3 - NMC 12s battery system - Lower voltage than 48V needed
somehow I need this to get to programmers of Victron team because I need to change the SW itself, it should be simple just some HEXADEC code change in app to lower the 48V limit for absorbtion and float voltages. I have a 50kWh of 12s NMC battery packs from VW ID3 and my ideal float voltage for summer would be 47V, I dont understat why is this historical limit there, makes no sence because if I just manually shut down the solar during the day it will stop at 47V anyway… Can you please make changes to the app so the 48V limit is not there? I dont want to hack the app itself, because my devices are under warranty.
Thank you
