Hi everyone,
I have three Victron Orion-Tr Smart 12/12-30A Isolated DC-DC chargers charging my 400Ah LiFePO4 house battery bank (2 × 200Ah).
For a long time, I have been struggling to get the full potential out of this setup and achieve a combined charging current close to 90A.
Last year, I replaced my original 110A alternator with a refurbished 180A alternator because the original one was struggling to keep up.
1. Charging at full power
I discovered that if I completely disable both Engine shutdown detection and Input voltage lock-out, all three chargers work perfectly and deliver approximately 90A combined.
The charging current remains stable, without interruptions or charger resets.
However, the input voltage reported by VictronConnect drops significantly:
Engine idling in neutral: 11.3–11.5V
While driving: 11.7–11.9V
These values seem very low to me. I am not sure whether this is caused by the alternator’s characteristics, insufficient alternator output at idle, excessive voltage drop in the wiring, or another electrical issue.
Despite the low input voltage, charging performance is excellent, and I would like to achieve this charging rate reliably and safely.
2. Testing an external engine-running signal
Following advice and information from another forum discussion, I decided to try an external engine-running signal connected to the Remote On/Off L terminals of all three chargers.
According to the manual, applying more than 7V to the L terminal activates the engine shutdown detection override.
All three chargers are installed at the rear of my vehicle. As a simple solution, I used the power supply for my reversing camera, which becomes active when I switch on my headlights. I normally switch the headlights on after starting the engine and off before shutting it down.
I measured approximately 12V at the camera’s power supply and connected this signal to the L terminals of all three Orion chargers.
Here are the results.
Test A: Engine shutdown detection ON, Input voltage lock-out ON (default settings)
Headlights ON: The external signal activates all three chargers, but the input voltage drops. Input voltage lock-out then kicks in and disables/restarts the chargers, resulting in poor charging performance.
Headlights OFF: The charging becomes stable and the input voltage returns to approximately 13.3V. However, the chargers do not consistently operate at full output. Sometimes only one or two chargers operate, and even when all three are charging, the combined current reaches only around 45A.
Test B: Engine shutdown detection ON, Input voltage lock-out OFF
Headlights ON: All three chargers deliver approximately 90A combined, but the input voltage drops below 12V, as described above.
Headlights OFF: The charging current drops to approximately 45A, and the input voltage returns to around 13.3V after approximately 10 seconds.
Engine OFF, headlights still OFF: All three chargers continue charging instead of shutting down.
This last behaviour is particularly concerning. Even though Engine shutdown detection is enabled, the chargers do not stop charging when I switch off the engine.
I have to disable each charger manually in VictronConnect, or re-enable Input voltage lock-out with its default settings, to stop the charging.
3. Questions
I would really appreciate your advice on the following:
Why does the input voltage drop to 11.3–11.9V when all three chargers operate at full power? Could this be caused by the alternator, insufficient output at idle, or excessive voltage drop in the cables and connections?
Why does Engine shutdown detection fail to stop the chargers when the engine is switched off and the external signal on the L terminals is no longer present?
Is using the reversing camera’s power supply as an external engine-running signal a suitable solution, or should I use a different signal source?
What would be the best way to configure these three Orion chargers to achieve close to 90A charging current while ensuring that charging stops automatically when the engine is switched off?
My goal is to get the maximum practical charging performance from my existing setup without compromising the starter battery or the vehicle’s electrical system. Turning On and Off all orions with headlight switch is really comfortable solution for me, because I have a habit to always turn it off before turning the engine off.
Thank you in advance for any advice!
