Victron DRF2659C
After I just got bounced out of the forum with this question, here it is again! So, it’s a Victron product that I want to use to transmit an RS485 signal from an inverter to a wallbox. Would it work with 2 DRF2659C?
Bounced? Topic was closed. No Victron components mentioned. This is a victron forum
Why not refer to your wall box and inverter manufacturer? Victron have their own EV charger that talks natively to the GX device and the vrm.
What Victron components do you have in this system?
The victron interface is for connecting victron energy meters to a victron inverter.
Your previous, closed, topic was about third party devices on both ends trying to use a device in an environment it isn’t built for.
Your question is best asked of your non-victron manufacturer about what they support.
In the absence of a victron inverter or wallbox, this topic is likely to be “bounced” as well.
No idea whether it works with other devices, but you need one DRF2659C and one DRF2658C.
The DRF2659C converts from RS485 to Zigbee, and the DRF2658C from Zigbee to USB.
When I ask about a Victron device, I expect a knowledgeable answer. As far as I know, an RS485 interface isn’t tied to a particular manufacturer, so it doesn’t matter what I want to connect the converters to. Since apparently nobody here knows whether RS485 can be transmitted, I’m bowing out of this discussion and signing off.
Nevertheless, this is a Victron forum, and Zigbee devices aren’t Victron products either. Victron only carries them to integrate the officially supported RS485 meters.
