Venus OS v3.90-beta7 - ESS State: Keep Batteries Charged not working
ESS State: ‘Keep Batteries Charged’ does not charge the batteries.
V3.90-beta6 and V3.90-beta7 have both the same behavior.
Reverting back to V3.81 the ESS State ‘Keep Batteries Charged’ works as expected.
How are you setting it - Old UI, new UI, VRM?
Through the iOS application & Beta VRM Chrome browser
Please try use a remote console, there are some control issues with VRM that have been reported. Several topics already open on this affecting production versions as well, so would be good to clarify the specifics. Thanks.
I have used keep charged on beta6, but activated via the current UI.
Ok, thanks i will test this and report back.
Used the V3.90-beta7 Remote console and it starts charging indeed.
But it is not charging with full load as set in Charge Control settings.
After some minutes the charging slowly decreases and goes over into discharging the battery and is increasing the discharge power slowly and this proces changes again into charging and then into discharging and to charging… very slow transit between both with low power.
Reverting back to V3.81 as it does not have these symptoms.
Ok, thanks. Need a bit more detail about your system and its configuration.
VRM Site ID 702684.
Is this sufficient?
What kind of batteries are you using? I am using Eco-Worthy and it reports as pylon batteries so the beta 7 firmware imposes a limit on charging regardless of what the BMS is asking for. I had to revert to 3.81 as well.
Basengreen packs with Tian Power BMS that uses Pylontech protocol.
VenusOS V3.85 all is okay too.
Then you may have the same issue I reported. They have created a ticket to address it.
Thanks!
You still have the issue with V3.90-beta9?
I did not yet test it.
Yes, beta 9 still has it. I had only gotten to 7 when I found the issue. 9 was already out.
Hopefully it will be addressed and solved in the next beta version.
