With Venus OS 3.90 beta1 through beta5, real-time power data and Remote Console still work, but VRM reports that it has lost contact with my Cerbo GX. Voltage, current and other values are no longer updated correctly.
After downgrading to 3.80, all values are transmitted again and VRM shows the connection as restored.
This is reproducible when switching between 3.90 beta and 3.80.
Data is being transmitted to VRM. The VRM status on the GX device shows no error. The VRM Portal shows “real-time” and status “OK” at the top. Pwer data is received and displayed in the upper power indicators. Remote Console works.
However, the VRM device list does not show a connection despite data being transmitted every minute (e.g. last contact >15 min for all devices at the site).
After 20 minutes, VRM triggers the alert that no data is being logged for the site: “This site has stopped reporting to VRM. Check the internet connection to the GX device.”
I don’t remember seeing an error but did the upgrade from 3.8.1 to 3.9.0~beta8 this afternoon and I’m now missing a couple of hours of data in VRM. I quickly rebooted back into 3.8.1 and problem is solved but it’s not bringing back the missing data.
Before I rebooted I checked the VRM section in the console and there was no connection to VRM. It also appeared no storage was detected (I use Cerbo without SD so only native storage to detect).
Jup, beta9 same problem. I can switch between 3.8.5 and boot into 3.9.0~9. It immediately breaks and does not show free diskspace on the device itself. Still “no error” and last contact remains empty.
Quite sure then that this will fix it for your system. It is on the list of patches to be added to the 3.90-beta11 release. Which likely arrives within a few days.
