Title: MOPEKA sensor problem
I have a Cerbo GX running Venus OS v3.81 and two MOPEKA sensors measuring the diesel in my boat’s tanks.
I’ve set up custom calibration curves so that the readings in litres correspond to the shape of each tank.
The problem is that, after restarting the Cerbo GX, the curves are still saved, but they seem to stop being applied correctly and the readings in litres no longer match the calibration.
I entered the adjustments again and the correct readings came back.
Has this happened to anyone else? Could it be a problem with Venus OS v3.81?
Thanks for your help.
