Venus OS v3.80~46 available for public testing
Really great to see this fix in after so long having Fuel [100], Fuel [101], etc! I tested and it’s working great with my four N2K senders. The capacity setting remains greyed out and unusable on N2k devices, and capacity (like name) is a nice thing to have settable for a tank. But great to have human readable names for the crew, thanks for getting this one!
Since 3.80-32 I get “High Discharge Current Alerts” on short load peaks…
Pylontech Battery. Peaks are around 50A.
Starting with version v3.80~33/v3.80~32 my SolarEdge SE4000 inverter, connected via modbus proxy, gets Active Power Limit set to 0, effectively disabling the inverter’s solar output. Switching back to the stable firmware fixes the issue. I have not seen this behaviour prior to v3.80~33 and came from version v3.80~27.
I have reverted that change. The idea was that a loss of communication will shut down SolarEdge inverters, like we do with inverters that support Sunspec-2018. In practice, it will require people to disable the limiting option in the PV-inverter menu whenever they are not using limiting, and I fear this will catch too many people unaware. So for the 3.80 release, this has been reverted.
I’ve tried out the new virtual indicators. They show up in the remote console but not in the VRM switch pane. I’m using betavrm. Is that supposed to work already?
For the EM Series, there was a bug, that the “wrong counter” was read, “Energy Forward” rather than “Energy Reversed”.
I think that was fixed, So if your EM was logically working until now, it is now “logically wrong orientation” still counting on the “Energy Forward” which is no longer read.
The Shelly App is supposed to report a negative Power for Solarproduction, then orientation is right and the correct counter should increase.
For the PM shellies, you may need to check the integration again, if their switch is turned on. There was also a bugfix of a index beeing off “1”, that could cause the integration to enable another discovered shelly, but your installed solar-metering-shellies.
Hi, haven’t seen anyone posting the bugs I found in 3.80 in general.
I’m now running 3.80~33
Some parts of the UI has a weird offset.
See some recktangles or some others stuff that is not looking great on the screen.
see my screenshots.
A pop-up what is half off screen.
The temperature bars are too tall and reach the quick links bar.
ESS outline is left instead of right for the other ones
George
@G-Energy0
Can you add some information about what device OS and browser etc that you are using. Sometimes the screen display size also matters fr scaling issues.
I’m using the VRM app on an Iphone 13 with IOS 26.5. [no matter if I use horizontal or vertical on this Iphone].
You’re right, the 2th screenshot with the RS system mode outline, is not wrong on my windows desktop VRM browser.
But apart from that, the rest is still there.
Thank you!
No, that is still under development. For now it is only the (remote) console.
Thanks for clarifying - I love this feature - was looking for this already - keep up the good work!
