Venus OS v3.80~46 available for public testing
Good day!
A fresh new thread for v3.80 beta feedback.
Change log below, and first please make yourself aware with the beta testing instructions:
Instructions 1 of 3: Venus OS beta testing & how to join/install
In case you don’t know what this message is about, please start with reading this link, which explains the Venus OS beta program. Venus OS is the software running on all our GX devices, such as the Cerbo GX.
Instructions 2 of 3: How to report an issue?
Before posting, please check if your issue already exists, in which case please contribute by replying to that issue or up-voting it.
Only once you are sure its a new possible issue, start a new topic.
Lastly, before posting, preferably first revert to the latest official release, to double check if the issue you’re seeing was present there as well. Regressions require a different treatment than other issues and bugs. And let us know if you did that, and what the difference is. A perfect report contains:
  • How its expected to work
  • How it doesn’t work as expected
  • Details on the system
  • What you’ve already tried to make sure its not a setting or other issue.
Please take note that that this works quite differently than it used to do on the old version of Community:
  • For a new issue, open a new topic. Instead of adding a new reply at the bottom.
  • To add to an already open issue, aka topic, reply to that. Or just upvote it if you have the same issue. This will help us a lot in determining its importance and manage our priorities.
Instructions 3 of 3: using Node-RED, Kevin’s SetupHelper, GuiMods, dbus-serialbattery or other add-ons?
Node-RED or Signal K
In case you are running Node-RED or SignalK, then please at least say so in your bug report.
Modifications such as the popular GuiMods, SetupHelper, dbus-serialbattery and other 3rd party add-ons: do not report new topics in Venus beta. Please do it elsewhere instead; and make sure to check out the related issue tracker first.
These topics and beta testing and bug reports are only for clean systems.
See SettingsGeneralModification checks in the New UI.
Popular bug report / discussion threads:
Change log
v3.80~46 - 04/09/26
  • New UI:
    • Do not unnecessarily clip tanks/sensors view when there are many.
  • Node-RED:
    • Fix storing user settings.
    • Fix a bug where input nodes with the “conditional evaluation” option enabled could lose their second output wire after reopening a flow in the editor.
    • Add a number of previously missing device data points (temperature air quality, battery alarm codes, DESS status, solar charger PV current, DC genset info, and more) that are now available to use in nodes.
v3.80~45 - 01/09/26
  • Shelly
    • Fix shelly (RGB) dimmers with fw version v2.0.0 no longer working.
    • Fix stuck device state when init fails.
    • Fix stopping channels on capability change.
  • Node-RED
    • Don’t exclude com.victronenergy.shelly from showing up in the custom nodes.
    • library updates.
  • Lynx Parrallel BMS:
    • Fix sometimes not finding all BMSes when switching from one CAN bus to the other.
v3.80~44 - 28/08/26
  • BLE bridge
    • Shelly devices can now be used as a VE.Smart instant read-out range extender.
      See ble-bridge for more details.
  • BLE
    • Add IAQS score for RuuviAir sensors.
  • EEBUS
    • Fix an issue where a device’s trust status could get stuck flipping between trusted/untrusted.
  • Multi RS
    • Add grid meter not found alarm.
  • New UI
    • AC System:
      • Rename “RS devices” to “Inverters”.
    • Battery:
      • Add cell measurements fault alarm.
      • Rename BMS cable fault to Battery communication fault.
    • Virtual Keyboard:
      • Rework UI auto-scroll response to virtual keyboard.
    • MQTT:
      • Device product names should not be translated.
    • UI:
      • Portrait: fix clicks on first button of navigation bar “more” dialog.
    • BLE sensors:
      • Add support for BLE bridge pairing.
    • WASM:
      • Add a workaround for the backspace of the virtualkeyboard not working on Garmin MFDs.
  • Node-RED
    • Virtual AC Load, Generator, and Heat pump devices are now easier to set up, with a single “use as grid meter only” checkbox replacing the old confusing Energy meter Role dropdown. EV charger (previously just a Role option on Energy meter) and Heat pump are now their own dedicated device types - EV charger remains a meter that only reports energy usage, not actual charging control.
  • Existing flows keep working unchanged.
v3.80~42
  • Important for EV Charging Station beta testers:
    • A breaking change is being introduced in the beta communication stack for the EV Charging Station. It affects testers using MQTT, Bluetooth, VictronConnect or VictronConnect-Remote, including Opportunity Loads testing.
    • When updating, these beta versions need to be upgraded together:
      • Venus OS: v3.80~42 or newer.
      • EVCS firmware: v2.09-beta-05 or newer.
      • VictronConnect: 6.50beta2 or newer.
    • Mixing these with the previous beta versions (Venus OS v3.80~39, EVCS v2.09-beta-04 or VC 6.50beta1) may cause communication issues.
    • Not affected: released/stable versions and the Venus OS Modbus integration for the EV Charging Station.
    • In short: If you use the EVCS beta via MQTT/Bluetooth/VictronConnect, update all three components together.
  • VE.Can:
    • Multi RS: Fix issue where setting items of a Multi RS 48/6000/100-50 (without solar) had no effect. This affected most of the writable items, like AC input current limit and (Dynamic) ESS related settings as AC power setpoint and feed-in limit. On/off control was not affected.
      • The bug exists since support of the Multi RS 48/6000/100-50 in Venus OS v3.67.
    • Smartswitch: inputs support for Energy Solutions SmartSwitchDC4.
      • Requires Energy Solutions SmartSwitchDC4 firmware >= v1.14
    • NMEA2000 inbound alerts: make the enable setting opt-out.
    • MGE BMS-es:
      • Fix voltage reading for high voltage BMS-es.
      • Add state-of-health.
  • EEBUS:
    • Update LPC & LPP D-Bus paths to follow PowerGuard specification.
    • Reduce heartbeat interval to work with Elli EV chargers.
    • Update EEBUS stack to fix a crash on some Elli EV chargers.
  • System:
    • Fix several bugs that caused the charge current limit to be exceeded when using multiple Multi-RS units with PV attached.
    • If the MPPTs were running absolutely at capacity, a rare condition, a zero division error was not fully handled and could fail to lower the charge limit.
    • Differences in how the performance of the Multi-RS vs regular MPPTs is measured caused a miscalculation, which could result in an incorrect limit.
    • A large downwards adjustment in charge current limit (more than half) would cause insufficient limiting to be applied.
    • Issue observed specifically with Cegasa batteries, but could also affect others.
    • Introduced in Venus v3.70~27.
  • E-drive:
    • Increase notification delay to 5s to prevent false positive emergency messages on Curtis controllers.
  • New UI:
    • Battery:
      • Hide battery bank settings menu when empty.
    • Bluetooth:
      • Add support for encrypted instant readout devices.
    • Boat:
      • Fix energy per distance unit conversion.
    • EVCS:
      • Show auto mode source and hide charge current in auto mode.
    • Generator:
      • Fix editing of the total run time.
      • Fix start/stop button height and allow Space key trigger.
    • Levels:
      • Fix min/max values for temperature gauges.
    • Notifications:
      • Dynamically update changes to existing notifications.
    • Settings:
      • Add BlueTooth sensors UDP/BLE gateway access setting.
      • Fix text fields sometimes being incorrectly aligned.
    • UI Controls:
      • Align text field height with button height in portrait.
      • Fix a bug where the generator total run time was shown as “NaN”.
    • WASM:
      • Fix touch events being lost on an iPhone after switching apps.
      • Prevent mobile WebViews from closing the on-screen keyboard.
  • VRM:
    • Fix EV charging stations listed in duplicate (introduced in Venus v3.80~26).
  • Node-RED:
    • Add phase and AC-side configuration for virtual AC load devices.
    • Fix the dropdown-type of the Virtual Switch value not being saved across restarts.
  • Developers:
    • update Node.js to v24.18.1.
v3.80~39
  • VE.Can:
    • Add support for NMEA2000 inbound alerts.
    • Fix valid types issue of the Smartswitch where a channel supported type could not be revoked. This issue was introduced in Venus OS v3.80~34.
  • mDNS:
    • Announce venus-[serial].local as well, e.g. venus-hq0123456789.local.
    • Advertise _victronenergy_http_pairing._tcp via DNS-SD so clients can discover GX devices that support MQTT token-based pairing without knowing the IP address in advance.
  • Modbus:
    • Add support for Datakom genset controllers.
  • Shelly:
    • Don’t allow pvinverter role when configured as opportunity load and vice versa.
    • Add support for CCT RPC component (e.g. Shelly duo bulb E27).
    • S2: Enforce on and off hystereses by rejecting invalid state transitions.
  • EEBUS:
    • Add new mDNS implementation to improve device discovery reliability.
  • Opportunity Loads:
    • Fix 0-settings reverting to default after reboot.
    • Fix a bug where devices were left in a on state during nightly sleep mode due to auto-learning a 0 power drain.
    • Add some enhancements for various system combinations.
    • Avoid disconnecting the EVCS during night, which made it fall back to internal auto, causing a short probe-charge.
  • New UI:
    • Boat: Improve charging state.
    • Opportunity Loads: Reorganize labels and explanations.
    • Overview: Show static arrows when animations are disabled in landscape.
    • Switches:
      • Update settings text and options for “permanent on” outputs.
      • Update polarity option text.
      • Update fuse detection options for “permanent on” outputs.
  • VRM backlog:
    • Ignore storage device if it contains runtime hook archive (venus-runtime-.{tar.gz,tgz,zip}).
v3.80~36
  • New UI:
    • Ac Inputs
      • Improve current limit presets.
    • Overview
      • Fix solar devices sort order in Solar drilldown.
      • Re-layout when DC input count changes.
    • Notifications
      • Fix delegate showing stale data.
    • Overview
      • Fix consumption energy indicator in portrait.
      • Hide energy flow in portrait layout when below noise threshold.
      • Swap left and right columns in portrait layout.
    • Settings
      • Fix ev charger consumption and production limits.
      • Add paired devices option to MQTT access settings.
    • Shelly
      • Rework settings page to show channels in sub-page.
    • VE.Bus
      • Separate W and V columns in Overview drilldown AC I/O table.
  • AC System:
    • Fix the Custom name so that it cannot be set to blank, it will default to “AC system (n)”. It caused the service to appear disconnected in the New UI.
  • Bluetooth:
    • Do not disconnect all devices on a keep alive timeout, but only the incoming VictronConnect connection.
  • Shelly:
    • Fix channel reinitialization.
      Improve channel enabling mechanism.
  • VE.Can:
    • Genset: add DVCC support for Fischer Panda AGT.
      • Requires fpControl firmware >= 0.35
      • Requires CI-SAEJ1939 gateway firmware >= 2.20
    • Smartswitch:
      • Support up to 252 channels.
      • Support for inputs.
      • Fix fuse limit min and max values.
      • Fix last hue lost when set from VE.Can.
  • SolarEdge:
    • Revert the feature where SolarEdge inverters reduce power to zero when losing comms (introduced in v3.80~33)
      • This caused PV-inverters to stop producing power in systems where the limiter is initialised, but not used.
      • There are ways around this, but for Venus 3.80, this is the better interim solution.
  • System:
    • Fix a bug where solarchargers were left unlimited in a system configured to feed in excess DC PV while powered by a genset. The current limit should only be lifted in cases where we actively want to feed excess DC PV into the grid.
  • Opportunity loads:
    • Fix unsuccessful detection for restricted feed-in on a Multi RS System.
  • Node-RED:
    • Improve s2 support for opportunity loads.
    • GPS UTC time was still not working reliably. A library update fixed that (regression from Venus v3.80~30)
    • Virtual PV inverter can now auto-calculate cumulative energy (kWh) from power values - no manual calculation needed.
    • Energy counters now survive Node-RED restarts across virtual PV inverter, AC load, grid meter, energy meter, and genset nodes.
    • Settings/Platform/System services no longer appear as duplicates in dropdowns after redeploy.
    • Importing or opening flows with unconfigured nodes no longer crashes Node-RED or the editor.
    • Fix a virtual GPS crash that occurred when the device reported the current time over the system bus (regression from Venus v3.80~30)
    • The Virtual AC Load node now calculates the Energy totals from the power readings.
    • Virtual AC load S2 energy management integration improved for opportunity loads integration.
    • Virtual EV node updated for better compatibility with the e-node connected EV’s to allow Dynamic ESS to schedule for charging.
    • Fix a bug where sending a message could unexpectedly modify the original message payload of the virtual switch.
    • Virtual nodes used inside subflows no longer fail due to invalid characters in the node ID.
    • Virtual switch nodes now show a live preview of how the control will look on your GX device, updating as you type.
    • The system input node now exposes individual ESS battery status reason codes (Low SoC, BatteryLife, charge/discharge limits, etc.)
  • Developers:
    • Update Node-RED to v4.1.11.
    • Update Node.js to v24.17.0.
v3.80~33
  • VE.Can:
    • Fix an issue where the address claim procedure would not complete under certain conditions (BUS-OFF), resulting in the GX no longer transmitting data on the network.
    • Fix unsuccessful detection of individual phase mode for grid tie systems.
  • Marine App:
    • Improvement performance of the switching pane.
  • Solar Edge:
    • Request the Solar Edge to disable power generation when the communication is lost instead of going to full power. This brings the SolarEdge implementation in line with the SunSpec IEEE 1547-2018 implementation; They will now behave the same as newer SunSpec inverters. (This time for real, it was incorrectly included in the v3.80~32 changelog)
    • Make sure the Solar Edge is shown on VRM (an issue in v3.80~16 caused it to be unavailable in some cases)
  • Developers:
    • The aarch64 SDK is now build for a cortexa53 (or compatible) target.
v3.80~32
  • VE.Bus:
    • Fix ESS assistant not always detected on S99 firmware after switching on the system.
  • VE.Can:
    • Devices that use the GX as configuration tool for switches can now populate the Output limit settings in the user interface to adjust the PWM range, while keeping the 0-100% dimming range in the switch pane.
  • Shelly:
    • The Shelly enable channel settings had an off by 1 error in their channel number during the beta cycle. This restores the behavior of the latest release, but this may change the enabled state of a channel compared to the previous version.
    • Do not allow the PV-Inverter role on dimmable devices.
    • Fix not being able to set the customname on some devices.
    • Correctly report energy when a Shelly is configured as PV-Inverter.
  • Solar Edge:
  • Parallel BMS:
    • Let the “Number of BMSes” field reflect the total number of BMSes that have been connected.
    • Use the “Redetect” button to clear the cache.
    • Issue a warning when the connection to a parallel BMS is lost.
  • System:
    • Fix a problem in three phase systems with PV-inverters where MPPTs stop producing energy instead of feeding it into the grid. Not all sites are affected, it depends on small differences in voltage readings, and relative size of AC- and DC-coupled PV.
    • This affects sites with a PV-inverter on the AC input side. When the battery reaches the charge voltage, the MPPT will stop producing while charging completes from AC-coupled PV. This loses production. The fix adds a 100mV offset to the MPPTs, when the Multi is charging and feeding in of excess DC-coupled PV is enabled.
  • New UI:
    • Boat: Add range, consumption, new gear indicator and optional temperatures.
    • DC Gensets: Fix navigation for DC input widget.
    • Settings:
      • Show ac-in consumption and production limit.
      • Warn user about disabling internet gateway.
    • Switches: Hide some input/output settings depending on product ID.
    • Tanks: Unify tank value decimals and step size.
    • UI: Remove “Press to” from all button texts.
    • VRM: Add sections to vrm device instances list.
  • Marine App:
    • Add support for RGB/CCT/RGBW color wheel and presets.
    • Add support for /GenericInput devices.
    • Add support for switchable output /Status reporting (Fault, Over temperature, …), and disabled state.
    • Improve the MFD capability check for using the New UI and disable animations when running on the MFD.
    • Add more granular WASM/JS/WebGL capability checks for MFD ↔ GUI-v2 compatibility.
  • Node-RED:
    • Fix duplicate entries appearing in service dropdowns.
    • Fix Virtual Switch STEPPED mode defaulting Max steps to 7, preserving the value on dialog reopen.
    • Add /UtcTime to the virtual GPS device and GPS input node; auto-injected when not set by the flow.
    • Fix grey nodes on startup - Nodes could appear grey (uninitialized) immediately after deploying a flow. Node registration now happens synchronously again, so all nodes initialize correctly on startup.
    • Virtual indicator: live SVG preview in the edit dialog - The virtual indicator node now shows a real-time SVG preview while you configure it. You can see exactly how the indicator will look before deploying the flow.
    • Virtual switch: Auto mode now works with leading-slash keys - A bug prevented the virtual switch from switching back to Auto mode when the incoming msg.payload key started with a / (e.g. /Auto).
  • Developers:
    • Update Linux to v6.12.90.
    • Update Node.js to v24.16.0.
v3.80~27
    • Turn surplus solar into useful work with GX Opportunity Loads, see Opportunity Loads for more information.
    • Note: the classic UI doesn’t support Opportunity Loads!
  • Classic UI:
    • Add support for pairing MQTT devices.
  • New UI:
    • Battery:
      • Do not show empty module-level alarm list if id is empty string.
    • DC Gensets:
      • Support multiple DC gensets.
    • DESS:
      • Fix the Mode menu item and opportunity load warning.
    • Solar:
      • Show correct state text in solar drilldowns.
      • Order solar trackers by tracker index instead of name.
      • Rename “Solar yield” to “Solar” in various places.
    • Settings:
      • Hide Wifi gateway field when Wifi internet access is disabled.
      • Separate local and UTC components in Date/Time settings.
    • Switches:
      • Allow stepped switch mode to be selected when output is off.
      • Fix restore dim level from memory.
    • UI:
      • Add demo mode indicator.
      • Ensure a switch in a disabled ListItem cannot be toggled.
  • VRM:
    • Detect anomolous energy counters / spikes.
  • System:
    • Add support for paralleled DC gensets.
    • When pairing with MQTT, MQTT will be enabled only for token users automatically.
  • Node-RED:
    • Support all locales. All locale info is rather large, but it is rather difficult to determine which parts are useful. They are now all available again.
v3.80~25
  • New UI:
    • The new UI its remote console now supports portrait mode!
    • AcLoads: display status for device if available.
    • Generic Inputs:
      • PrimaryLabel should override reserved unit label.
      • show input text label and correct unit in summary text.
    • Genset:
      • Enable support for generators with /EnableRemoteStartMode.
      • Provide means to trigger clearing errors.
    • Modbus: show the device name for Modbus service on Wasm/MQTT.
    • Key navigation: fix navigation in nested views.
    • Switches:
      • Do not show inputs/outputs without a /Name.
      • Omit Inputs/Outputs submenu when there is only one item.
      • Ensure momentary button is released.
      • Fix function text when not supported.
      • Support switches without type and valid types.
  • VE.Can:
    • Support custom names in multi-tanks setups.
  • EEBUS:
    • EEBUS stack fixes to support Viessmann devices.
  • Node-RED:
    • Update Node-RED to 4.1.10.
    • Victron Energy Nodes:
      • Add hysteresis option to the conditional check for all input nodes.
      • The inject event node no longer requires a configured title.
      • The virtual temperature sensor only supported 2 types, now it supports the default 6.
      • Virtual EV updates to automatically updated /LastUpdated fields.
      • Add an Inject Event node to send custom events directly to the VRM event log, making it easier to track automation actions, alerts, and milestones alongside system data.
      • Add a Virtual Indicator node to the node palette, complete with documentation.
      • Add support for a Virtual Pulse Meter device type, allowing virtual pulse meters to be created on Venus OS from Node-RED.
      • Simplify Virtual Switch control. Send a plain value (for example 0 or 1) as msg.payload to control the default switch or indicator path, without wrapping it in a {“path”: value} object.
      • Add manual override protection for the Virtual Three-State Switch. A new “Apply input” option allows Node-RED automations to be ignored while the switch is in manual mode on the GX device. The default setting (“Auto only”) prevents manual user changes from being overridden until auto mode is restored.
      • Add the missing AC frequency path to the AC Load node.
  • Signal K:
    • Update Signal K Server to v2.27.0.
  • Other:
    • Motordrive: use the discharge floor setting to correctly estimate the range.
    • Improve the Pylontech charge voltage calculation, and improve resetting SOC to 100%.
      This applies only to 15-cell batteries that is not capable of doing their own voltage control
      The highest cell is now pushed to 3.52V, to more reliably reset the SOC estimate to 100%.
      The voltage is more reliably dimmed to lower values, if you have a severely low cell.
v3.80~22
  • New UI:
    • Show the voltage in the switchable output page when available.
    • Fix floating point step size for Numeric Input switches.
  • VE.Can:
    • Add incoming power snapshots support for VM-3P5A. (also in v3.73)
    • Add support for the power message to the grid forward as sent by VM-3P5A.
    • Add accumulated DC energy produced for Fischer Panda and Hatz DC gensets.
  • E-drive:
    • Fix unwanted notifications on Oceanvolt systems during shutdown.
    • Add more Sevcon fault codes.
  • VRM:
    • Filter invalid energy counters to prevent large spikes on VRM.
v3.80~21
  • New UI:
    • Add an ESS system reason number for peak shaving.
    • Support unit conversion in the electric vehicle page.
    • Add EEBUS support to the integrations section.
    • Add Japanese translations.
    • Support pairing of MQTT Devices.
    • Add droop graphs to the device settings page for Microgrid.
    • Add channel direction configuration for the Energy Solution SmartSwitch.
    • Use 1-decimal and 1 Ω step for in the resistive tank sensor setup.
    • Clicking the WiFi and gsm icon on the overview now opens the relevant page.
    • Fix the audible alarm setting not working when the Classic UI has never been used.
  • EEBUS:
    • EEBUS is an open, vendor-neutral communication standard for home energy management systems, enabling standardized energy-data exchange with compatible devices.
    • This initial release adds support for the EEBUS Monitoring Power Consumption (MPC) use case, allowing GX devices to monitor the consumption of compatible heat pumps and EV chargers.
    • The implementation has been successfully tested with NIBE S-series heat pumps and Bender CC613 Charge Controllers.
    • Known limitations: Only one EEBUS device can be connected at a time.
  • SMA inverters:
    • Fix a problem where some SMA inverters were not detected on VRM if they are not installed on L1.
  • Modbus:
    • Add register 2724 to disable PV-inverters completely in ESS systems with VE.Bus inverters.
    • Add registers 4929 to disable PV in Multi-RS systems.
    • Add registers for changing switching microgrid operation (registers 232-234).
    • Add registers for microgrid hybrid droop, and grid-following active and passive power @100% references (registers 240-246).
  • MQTT:
    • Support pairing of devices. This can be done from the New UI and on a Cerbo by pressing the button twice.
    • It allows pairing for 2 minutes. The Bluetooth led will blink fast during this time on Cerbo.
    • This is in preparation for future integrations.
  • Shelly:
    • Periodically retry connecting to listed manual IP addresses.
    • Add retry mechanism on device name fetch.
    • Restrict forward energy values to be nonzero, fixes sudden spikes/drops in VRM graphs.
    • Report absolute current and power, fixes negative current/power values for pvinverter role.
    • Fix refresh button not working properly.
    • Improve identification of shelly devices which do not have a name set.
  • Bluetooth:
    • Fix the Firmware Version for Gobius.
    • Add support for Pro-200B Mopeka sensor.
    • Add support for Garnet SeeLevel sensors.
  • E-drives:
    • Support older versions of the Curtis E/SE controllers.
  • CAN-bus BMS:
    • Add Voltsmile battery support.
  • ESS/Battery-Life:
    • Auto-recharge now activates based on the active SOC limit rather than the minimum SOC limit. Before this change, if the user-configured minimum soc was much lower than the battery-life soc, the battery could discharge quite deeply before auto-recharge kicked in. In systems that do peak-shaving, this is detrimental, and can cause the battery to never reach absorption. Now the battery SOC is kept closer to the active SOC limit.
  • VRM:
    • Improve the PV->battery and PV->consumption energy estimates. This affects all systems except systems that have “Show DC loads” configured, with a suitable battery monitor (SmartShunt, BMV, Lynx, some third-party BMSes). The DC consumption is estimated from the AC energy meters in the Multi, but conversion efficiency was considered, causing the conversion losses to show up as battery charging. These conversion losses were allocated to the battery even after the battery was full. Systems that feed excess DC PV into the grid could end up showing as much as double the battery capacity as PV->Battery.
    • Support remote firmware updates for the Pytes BMS.
  • Node-RED:
    • The Virtual switch and indicator nodes now show custom name, group, and device type in the nodes label (if name not explicitly set).
    • Fix the energy counter properties incorrectly defaulting to 0, thus preventing large jumps in VRM graphs.
    • Fix the EV charger ChargingState enum values to match the Venus OS D-Bus spec.
    • Fix the /State path (Running = 0x100) missing from virtual switch and indicator nodes.
    • Fix null D-Bus paths being hidden in standard input/output node dropdowns - they now show as ‘- (null)’.
    • Fix missing ProductId for generator and e-drive virtual device types.
    • Add a new virtual indicator node - a powerful way to display any custom value directly on your GX device screen and in the VRM switch pane. Whether it’s data from an external sensor, a calculated value, or anything else your Node-RED flow produces, you can now push it to the GX display and have it show up alongside your regular system data. Supports numeric values (with configurable units and decimals), text, and discrete state labels, and values can be grouped into named cards on the display.
    • Add a new virtual DC load device, so you can represent DC consumers in your Node-RED flows without physical hardware.
    • The virtual weather station (meteo) node now also exposes installation power, and a small label error was fixed.
    • History/ChargedEnergy and History/DischargedEnergy fields are added to the Virtual Battery to keep track of the total energy in and out (kWh) of the battery. It is saved across restarts.
    • The “last contact” timestamp updates automatically whenever any virtual Electrical Vehicle property changes.
    • Error reporting of the Virtual Generator was using the wrong field name and type, causing compatibility issues. This is corrected to match real Victron Energy hardware.
    • Allow editing of consumption forecast with the VRM-API node.
    • The VRM-API node no longer gets stuck on ‘Connecting to VRM API’ when a request fails, and the forceIpv4 setting now works correctly.
  • Developers:
    • Add a terminal to the new UI in super user mode on a physical screen. Switching can be done with ALT F1 and ALT F2. CTRL + and CTRL - changes the font size.
    • Work is being done on supporting New UI plugins. See How to create GUIv2 UI Plugins · victronenergy/gui-v2 Wiki · GitHub for more information. Adding custom pages in Settings->Integrations and adding new device pages is currently supported.
v3.80~14
  • Node-RED:
    • Fix a crash on flow load when a settings service node was present. The migration path incorrectly treated it as a legacy node and crashed on a null device instance (TypeError: Cannot read properties of null)
    • Restore MaxChargeVoltage to the settings node, which had been accidentally dropped during the services.json refactor in March 2025
    • Fix that users who previously installed victron-vrm-api manually would silently keep running that outdated (0.2.x) version even after a firmware update. Venus OS now automatically removes the stale local copy on startup, ensuring the firmware-bundled version is always used.
v3.80~13
  • Shelly:
    • Allow changing customname when shelly channel name is not set yet.
    • Allow more EM roles for switching devices with EM: acload, pvinverter, heatpump.
    • Allow more EM roles for dedicated EM: acload, pvinverter, genset, heatpump.
    • Improve handling of devices which are in the manual IP list but are also discovered over mDNS.
  • Lynx parallel BMS
    • Add min/max cell voltage information to the parallel BMS service.
v3.80~11
  • DC loads:
    • Consider DC genset power when estimating the DC loads in systems configured to display DC loads. Thanks @stefanor.
  • Node-RED:
    • Fix missing dropdown for config nodes that use paths from the settings service.
    • Add an option to the Virtual Switch to show / hide the switch in Local UI (console via LAN and physical screen) and / or Remote UI (VRM).
    • Correctly prefix the virtual-device-types endpoint with httpAdminRoot as it causes issues is Node-RED is not in the root path, e.g. fixing issues for SignalK users.
    • Add support for fetching the DESS schedule for EV Charging, Heating, AC Load and base Load Consumption to the VRM API node.
    • Add support for adjust Consumption Forecast to the VRM API node (beta).
  • DESS:
    • Fix a bug causing the Multi RS throttling solar when charging from the grid.
v3.80~9
  • New UI
    • Show the correct values in the overviews when AC-In1 is set to unavailable and AC-In2 is used.
    • Fix the step size of basic sliders. Thanks to @most4radler.
    • Show a note when generator Warm-Up / Cool-Down requires newer inverter/charger firmware.
    • Correctly display custom units on Generic Inputs.
    • Add icons to the support status page, instead of only changing colors, since that might be difficult to see for color blind people.
    • Update translations
  • Node-RED
    • Virtual Energy Meter - supports multiple roles: grid meter, EV charger, heat pump, AC load, inverter, generator.
    • Add ‘Virtual Electric Vehicle’ as an option to the ‘Virtual Device’.
    • Add an Output node for Alternator / Orion XS in Charger mode to allow to control it.
    • Add an example flow for making sure all AC parallel phase are balanced in a 3-phase Quattro systems.
    • Remove the deprecated Switch type from the Virtual Device node. New setups should use the Virtual Switch node instead.
    • VRM API: Add EV charging consumption, Heating consumption and AC load consumption. Both forecast and historical data.
  • Changes of v3.72, see Venus OS v3.72 - released officially
v3.80~8
  • VE.Bus
    • Fix VE.Bus BMS V2/NG BMS status when its remote switch is set to off. When the VE.Bus BMS remote switch input is set to off the whole system should stop using the battery. Thanks to @Matt.
  • Shelly
    • Device support changes
      • Support for ‘PM1’ RPC component (e.g. PM mini gen3).
      • Support Single phase EM.
      • Support multiple dimmer channels.
      • Support devices with mixed capabilities (e.g. Pro EM50 with two single-phase EM’s and one switch channel).
    • Refresh shelly device information in the discovery when its capabilities change.
    • Sync device channel name to both service customname and switch customname. more info here
v3.80~7
  • General
    • Carlo Gavazzi
      • Add support for the Carlo Gavazzi EM530-RG and EM530-MV meters. These are new additions to the EM500 family. The -RG model uses Rogowski coils, the -MV model uses 333mV current sensors.
    • VE.Can
      • Fix the VRM instance for Skylla-i/IP44/IP65 and BlueSolar VE.Can MPPT 150/70 & 150/85 chargers. In v3.70 these were accidentally different than before.
    • Modbus TCP server:
      • Fix several small issues with overlapping registers.
      • Add missing Lynx BMS alarms.
      • Add 32-bit registers for maximum inverter power and maximum feed-in power.
      • Add registers to read/write the Custom names of several devices or services.
  • Large image
    • Node-RED
      • Update the server to v4.1.6
      • Virtual Device
        • The presence of a virtual device on the dbus and hence on a GX display and VRM portal can now be controller using msg.connected.
        • Add extra paths for the virtual battery.
      • Virtual Switch
        • A new output is now available on the Three-state switch showing whether the GX device is controlling the switch automatically.
        • Improve the status display of the Bilge pump.
        • The Switch state is now visible in the node status in the Node-RED editor.
    • Update Signal K to v2.22.1
  • Developers
    • OpenSSL has been updated to v3.5.5
v3.80~5
  • General
    • VE.Can
      • Fix running hours being capped for Fischer Panda gensets. Thanks @Stefano
      • Fix DC power for Fischer Panda DC models.
      • Add support for the VM-3P5A Energy meter (also in v3.73)
    • Motor Drives
      • Correctly report negative motor torque for Sevcon.
    • Marine MFD HTML5 App
      • Respect electrical unit setting configured to Mixed mode. Thanks @UnixWizard, @enrique_carrasco
      • Properly handle unrecognized unit configuration.
  • developers
    • Modbus-TCP Server
      • Fix register clash affecting Lynx SmartLithium batteries. There was a clash between registers 1318-1321, the highest temperature cell ID on CAN-bms batteries, and SmartLithium alarms. These have been move upwards.
v3.80~4
  • New UI
    • The Switch Pane now also supports generic inputs.
    • The function of a switch can now be set.
    • Fix the stepsize of the Temperature Slider.
  • Node-RED
    • Restore the ability of custom control node to write to system paths (regression in v3.70).
    • Add the EV charging session energy to the EV Charger node.
  • VE.Can
    • Fix channel 1 and 2 Energy Solution SmartSwitch DC4 being hidden (regression in v3.70).
      Add motor drive support N2K-out
v3.80~3
Prevent a possible long boot delay when a USB Pen Drive is present. It seems to depend on the system if this occurs, but when it occurs there is a 150s delay, potentially leading to BMS lost events. Thanks @Nicolas.
v3.80~2
General
  • Motor Drives
    • Report a more stable RPM when idling.
    • Correctly report negative temperature and current for the Curtis F.
  • Peak shaving: Fix Peak Shaving shaving issues introduced in Venus OS v3.70.
  • GX GSM/LTE/4G modem: Fix connection to Three UK. This might be related to the UK shutting down 3G support, so potentially helps for more network service providers.
  • EVCS charging station: Fix an issue where multiple EVs or EV charging stations in a system could disconnect simultaneously when only one became unavailable.
  • Pulse Meter: Reset the aggregate when the count is reset.
  • Victron Energy Node-RED pallette updates: Various fixes
Under water / developers:
  • Node.js has been updated to 20.20.0
  • Rust has been updated to v2.61.3
Heads up: Tomorrow, the 11th of March, we will switch beta to v3.71~1. (Since we are mainly focusing on fixing issues at the moment, it will be almost equal to v3.80~5 though)
for the moment this continues at Venus OS v3.71~2 available for public testing and there after here again.
HEADS UP: Venus will be switching to v3.72~nn soon. If you don’t want that, then don’t update to that version.
Installed ~14 without problems on MP2 5k/48v GX.
I have one question : wil the virtual loads configured in node red be shown on the console and in the vrm portal in the future?
For software components in the large image, nodered, signalk etc, please post in their relevant sections - nodered and modifications.
There is a beta tag for both, please add that to the post.
There is no need to add cross links to those posts here, that is what the tag is for.
The core venus OS team is not responsible for those components and can’t help here, there are dedicated teams who will from time to time look for those tags.
Thanks for understanding.
