Venus OS v3.71: shore current limit locked in New UI but editable in Classic UI
I am reporting a suspected New UI issue on a Cerbo GX in an RV with two Quattro 24/5000/120-2x100 120V inverter/chargers.
Firmware: Venus OS v3.71; build date/time 20260315163256.
Operating conditions: Connected to a 30 A shore supply; generator stopped. The New UI identifies the active source as Shore and shows Active AC Input = AC input 1.
Observed behavior / reproduction:
  1. In New UI, the shore current limit showed 34.0 A and was grayed out. Tapping it displayed: “This current limit is fixed in the system configuration. It cannot be adjusted.”
  2. The same restriction appeared in both the Quattro device page and the Controls pane.
  3. Switching to Classic UI allowed the Input current limit editor to open and the value to be changed to 30.0 A.
  4. Switching back to New UI made the shore limit non-adjustable again, with the same fixed-configuration message.
I had been able to adjust the limit the previous day. No VEConfigure changes were made during this comparison; only the user interface was switched. The generator limit also appears grayed out at 50.0 A, but I am not requesting a change to that limit.
Expected: Both interfaces should agree about whether the active shore input limit can be adjusted.
Workaround: Use Classic UI to access the input-current-limit editor. I have not independently verified the effective current-limit enforcement, so this report concerns the reproducible interface discrepancy rather than claiming a confirmed control failure.
Is this a known issue in v3.71, and is there an official firmware version that fixes it? Please advise which additional diagnostics would help. I have photos of the firmware page and both interfaces.
3.71 is half a year old, the current version is 3.81.
It’s worth trying to update.
Sure - let me try that! Thanks.
