Good morning today!
v3.70 beta testing is temporarily on hold to validate v3.67 before making that an official version.
The latest v3.70 beta version install files are still available for download for those who need them, here. To install, use the off line .swu method documented in the GX manuals.
Full change log below, and first please make yourself aware with the beta testing instructions:
Instructions 1 of 3: Venus OS beta testing & how to join/install
In case you don’t know what this message is about, please start with reading this link, which explains the Venus OS beta program. Venus OS is the software running on all our GX devices, such as the Cerbo GX.
Instructions 2 of 3: How to report an issue?
Before posting, please check if your issue already exists, in which case please contribute by replying to that issue or up-voting it.
Only once you are sure its a new possible issue, start a new topic.
Lastly, before posting, preferably first revert to the latest official release, to double check if the issue you’re seeing was present there as well. Regressions require a different treatment than other issues and bugs. And let us know if you did that, and what the difference is. A perfect report contains:
- How its expected to work
- How it doesn’t work as expected
- Details on the system
- What you’ve already tried to make sure its not a setting or other issue.
Please take note that that this works quite differently than it used to do on the old version of Community:
- For a new issue, open a new topic. Instead of adding a new reply at the bottom.
- To add to an already open issue, aka topic, reply to that. Or just upvote it if you have the same issue. This will help us a lot in determining its importance and manage our priorities.
Instructions 3 of 3: using Node-RED, Kevin’s SetupHelper, GuiMods, dbus-serialbattery or other add-ons?
Node-RED or Signal K
In case you are running Node-RED or SignalK, then please at least say so in your bug report.
Modifications such as the popular GuiMods, SetupHelper, dbus-serialbattery and other 3rd party add-ons: do not report your issues here. Please do it elsewhere instead; and make sure to check out the related issue tracker first.
These topics and beta testing and bug reports are only for clean systems.
Change log
v3.67~2
- Add support for Gobius C tank sensors, wirelessly (Bluetooth)
- Add support for the new Ruuvi Air sensors. Note that this only involves read-out of temperature and other . Read-out of the air quality parameters will be part of the -future- Venus OS v3.70 release.
- Lynx BMS NG: Add cell IDs for the cells having the lowest and highest voltage as well as the cells having the lowest and highest temperature. The cell id consists of the last part of the Batteries serial number, then a dash, and then the number of the cell.The IDs are displayed in the GX menu’s like here:
And here on the VRM Portal on the Advanced page in the graphs:
- ESS: Fix bug in peak shaving function when the “Self-consumption from battery” setting is set to “Only critical loads”.
- DVCC: Fix bug where charge current limit on the Multi in systems without a BMS, or systems with a VE.Bus BMS, would not be correctly applied: switching the Multi off, and then adjusting the Maximum charge current limit in the DVCC menu, would not be applied when the Multi was turned back on. Instead the Multi would charge at the maximum it was configured for.
- Fix Error mk2vsc-61 which could occur during during Remote VE.Bus firmware updates / remote configuration.
- Fix the Genset Daily run time menu showing empty lines in the Classic UI.
- GX IO-Extender: Fix invalid “Output fault” being raised when switching the bi-stable relays rapidly.
- Fix bug in combination with Wakespeed alternators, that resulted in all data continuously appearing and disappearing again from the GX display when the battery is full in combination with a few more specific conditions.
- Inverter RS: Add State of charge & Time to go information
- Lower level / core OS security updates & patches
