Venus OS v3.50~9 WASM load speed
Is it just me or did it load WASM-gui a waaaaaayyyy much faster? If so, next do something about the cpu-load or we will kill the environment.
Yes I can confirm that GUI-V2 in v3.50~9 loads faster (earlier) in the boot process
Indeed. what we did is disable the splash screen fade-out animations on WASM. Ie. in your browser, no more load animations.
Only the GX device still does the animation (of the curved gauges) at boot.
Its much better now.
what do you mean with that @tuju ?
When I switch to the Overview pane, desktop computer’s fan starts. It obviously is the most cpu intensive of them all. I assume because the flow imitation bubbles on connecting lines. Those are the first to show sluggishness if system is overloaded.
Could be that indeed; or many other things: the code stack wrt that browser view of the UI is a complex one. We’ll look at it; but probably a bit later. For now I don’t see that has highest priority or blocker for official release with gui-v2
Functional bugs + CPU on the GX + the security changes have priority
An idea might be to have an on/off switch for all animations in the UI, both local and web, or perhaps one for each.
