I am quite new to the Victron world, and just ordered some stuff from Victron to extend the storage capacity of my existing PV setup. I am currently using a Tripower 8.0 SE and Sunny Home Manager 2.0 from SMA. I was quite positively surprised, that there already is a cummunity created tool to use the Home Manager as a grid meter, and also that I could already start testing Venus OS on a Raspberry.
However I am seeing a quite strange behaviour. I have added the Tripower as a inverter in my Venus OS and the Home Manager as the Grid meter. Both units are showing correct values. However the Dashboard does not show the PV Inverter, and the AC loads are not correctly calculated. Instead of calculating the difference between PV Inverter and Grid Meter, it seems only the positive phases of the grid meter (coming from utility grid) are summed up, negative phases measurements are ignored.
Is this a known bug, or maybe caused by not yet having a Victron Inverter in the system?
This is my current dashboard. As you can see AC grid is correct and the inverter shows up but has no total power. When looking in the device itself, total power shows normally, but no Voltage/Current for the total (which is correct with a 3-phase system, I assume):
