Hi, after upgrading to OS 3.81 my Installation ist showing a BMS Lost for my MP2 48/5000 connected via MK3 USB Interface to my Cerbo GX. The BMS ist definitly there. The MP2 ist only for Charging the Battery via a Generator and my Main-System ist working normaly.
As it worked perfectly with version 3.80, I assume it will work again. As I switched from 3.81 to 3.90–5, the 3.80 boot image is no longer on the Cerbo and I’d have to install it via USB. I’d rather wait for a potential fix and leave the system as it is, in case that helps you with troubleshooting. I can always revert to version 3.80 later.
My hunch turned out to be right… I had to physically disconnect the MK3 adapter from the Cerbo GX once, and switch the MP2 for the generator to OFF and then back to ON… The error’s gone and the thread can be closed
