finally updated my Raspberry pi 3b from 3.55 to 3.72… what a mistake! Screen is messed up now. specifically the touch screen no longer times out and dims, the touch calibration is gone. In fact its upsidedown and reversed! SSH login password was reset. and because of the touch issue it took me hours to successfully set a password to be able to login! Add to that even if you select “classic GUI” for the remote session, you still get the “NEW GUI” which is missing menu options. Add to that when the device reboots it doesn’t land on the display page that shows you consumption, energy flow, etc. it lands on the first menu page and its almost impossible to change pages because of the touch calibration issue.
in 3.72, how do I fix the touch screen calibration issue as GUIMODS no longer seems to work. is there an alternate method for addressing this?
Also the option to revert back to 3.55 is not an option in 3.72! Looks like that got messed up too
I understand that Victron is producing these builds for us DIY’ers and its open source, but this latest build has some seriously basic issues!
I have a RPI 4 and v3.72 works without incident on it. I do not think it is a generic problem with v3.72.
GuiMods alone is not enough to set up all touchscreens. Some work without any tweaks while others need changes to /uboot/config.txt. For these, including rotating the display, I have a package called RpiDisplaySetup that provides a command-line setup script to help with these tweaks and also touchscreen calibration.
Hi Kevin, I am having a similar issue as the original poster, except I need to run my touchscreen inverted. The image will invert fine, but I cannot get the touch functionality to invert even after calibration. It is a 5" Waveshare capacitive touchscreen that worked well previously before upgrading my Venus OS to the new version 3.72. I previously had the version with only GUIv1, 3.42. Thank you in advance for any ideas to try.
I’m sorry but I don’t have any suggestions. It’s been a long time since I’ve run an HDMI display and don’t currently have a setup for testing one. The last time I did test an HDMI touch display, the touch rotated with the image. Also, different displays have different behavior.
Thanks Kevin. I just drilled some new holes in the wall, rerouted some cables, and physically flipped the screen around. Hardware solution for a software problem.
