Venus OS 3.50+ and Raspberry Pi 4 working - Halfway
So, I read through the Raspberry pi not starting up forum and wanted to add my 2 cents to help others out.
I was running a prior venus OS on my PI4 but went down an easier route for upgrading:
I auto updated the Venus OS within the PI (Firmware/Online Updates) and selected the official 3.50.
After installing and rebooting, you will need a USB keybord, connected directly to the PI and use these commands on the PI:
CTRL + l (That’s an “L”, to clear the screen)
mount -o remount,rw /dev/root / (to change the filesystem from Read Only to Writable)
mv /etc/venus/headless /etc/venus/headless.off (same steps as in many other instructions on the forums)
reboot (will restart the PI)
Once it loads up, I had 3.50 installed but no new interface nor the “DISPLAY & LANGUAGE” tab.
Next, I loaded within the PI, the Beta 3.51+ OS and used the same commands above with the keyboard.
Then I reloaded again the official 3.50 and typed in the keyboard commands again (eveytime you update, you’ll have to type in the commands with a keyboard) and once more back to the Beta. It’s possible I didn’t have to do this as many times as I did but I read it may not take on a first or second try.
I now found that I had the DISPLAY & LANGUAGE tab, selected USER INTERFACE (REMOTE CONSOLE) > NEW UI
Then I went down to my Solar Station, plugged the USB to MPPT cables in and powered the PI up. It rebooted so many times, that I just walked away, went upstairs to my desktop and logged in remotely (https://192.xxx.x.xx) and was presented with the new interface, followed all the prompts and whalla! I have the new UI (remotely).
What I don’t have and not sure if its because I didn’t install another required file or 3.50 & Beta are not fully functional yet on the PI 4, is the new UI. I still have the prior UI on the PI, even though its running v3.51~2.
So, I am halfway there.
If anyone can help on what might be the reason the new UI is not displaying on the PI, I would appreciate it. Might it have something to do with the .swu files?
The new UI is not available to raspberry PI display yet. It still needs some work on the graphical engine due to the new display method used on GUI 2.0.
It does works with local lan on a browser, VRM or better, a phone/tablet using the new software
This is also documented in the UI changelog in the new UI category and in an existing topic in this section Raspberry Pi and GUI V2 - #9 by mpvader
