Venus delay
i need to display Quattro information on display(DSE M840) . I am using Vebus of Quattro to Venus gx and from Venus to DSE M840 through Modbus TCP. But it takes 3 to 5 minutes to display information on M840. Why it take so long ? I need information when the system turns and display information within 10 seconds. Why it take 3 to 5 minutes to transfer information?
Are the IP addresses set up correctly? Are you using a switch between the devices, or are they connected directly?
Have you checked the GX to see if there are any error messages in the Modbus TCP section?
yes IP’s are fine and they are connected directly. NO modbus tcp error.
