VE Smartshunt cut off at 35 pc
(Hundreds mustuv ready asked:) Why did Smartshunt cut off at 35% LFP battery. (I guess)
I set discharge floor 10% I’ll wait for the rain to stop try disconnecting Smartshunt to check.
Smart shunts dont have a cut off function that I’m aware of. Perhaps your BMS did the cutting off?
You are right I don’t know Battery SOC was (Calibrated on Smartcharge) 35%
I have redundancy. removed the shunt. Cloudy in Brisvegas, I will wait for voltage to reach 14.20, then recalibrate 100% and Move on.
Onya Mike.
I wonder what Shunt ‘discharge floor’ means?
Found the below on line:
The Discharge floor setting is used by the battery monitor to calculate the time to empty, but it really tells you the time to 50% empty.
So this just affects the TTG display.
The shunt need not be removed from the system, just the SOC and TTG displays will be inaccurate until reset to 100%
Legend!
Thank you Mike.
