Anyway Here is my issue. I have the above mention easy solar it is 7 years old now and I have had no issue until recently. I also have a 8500W Generator that I use to charge the BYD Battery box pro 13.8KWH but recently when I am charging the battery with the generator the inverter cuts our and the incoming AC charge Drops to zero but after a few seconds it cuts back in again. I dropped the incoming AMps to 41as this was 50 amps originally.so the inverter light goes out and the mains on and bulk light come on when it is charging it alternates between them.
I just hope this will not damage the inverter as it has never done this before and no settings have been changed.
Ant help in understanding this or how to alleviate the issue would be very much appreciated. If more info is needed please let me know and i will up load a photo or update the post Thank you.
Sorry I have had a storke in January and my typing is a little frustrating.
Yes that is when charging stop for as short while then starts again
I am currently at 51% Battery and tomorrow is a sunny day This should get me through I will look into any other suggestion when I can. Thank you so much for taking the time to help I have always found this community to be very helpful thanks a gain
Switching to charger only on the inverter might help for now.
Alternatively going lower on the input current limit until the connection stability is sorted. Or starting low and then working it up.
Is the generator also part of the original install or is it a later addition?
Just thought I would update on this. So I dropped the charge current down to 10 amps this works and I don’t get the inverter issue of cutting in and out. I have increased it today to 15 amp as yesterday I charged at 13amp all with no issues.
Thank you LX for your input and help on this I am now able to charge my battery without the worry of breaking it. Now if only the rain would piss off and give me some sun lol.
Thanks to everyone that helped and I hope this may also help someone else, have a great night and enjoy the upcoming weekend
