VE.Direct TX Output cable on Orion XS
The VE.Direct TX Output cable adds additional output functions to some MPPTs by using the VE.Direct ports TX pin.
It would be cool to be able to use the same cable on an Orion XS with these software options as examples:
  • Engine running detected. TX pin goes high if the Orion detects the engine is running
  • Charging active. The TX pin goes high if the Orion is in bulk or absorbtion phase
  • Charging finished. The TX pin goes high if the Orion is in float or storage phase
I would love to have that too.
Hello Victron :waving_hand:
