Are there efficiently curves available for the VE Direct inverters. I am trying to properly size the inverter and would like to size the inverter based on the actual running watts and expected efficiency. I see the single efficiency rating for each model listed in the spec sheet, but would like to see the full curve. I ve contacted Victron directly who redirected me to my seller, who did not get back to me.
You size the inverter for maximum Watts load at temperature.
The efficiency is the DC to AC conversion efficiency so it does not affect the output Wts unless you have a limited DC input, at which point you should fit a larger battery bank.
