VE Can Splitter into a Cerbo GX
Has anyone successfully done this? I have a VE Can cable going to a Garmin MFD and am looking to add a Wakespeed regulator. Thanks
VE Can is a daisy chain system so you do not need splitters. You go from one VE Van port on the Cerbo to the Garmin and the other VE Can port to the Wakespeed. All devices need to run at the same speed. The two end devices have a terminator. Do not forget you need a cross over cable to the Wakespeed as the pin out is different.
Look in the Wakespeed section of the manual, it shows the WS500 and a BMS both connected, you would do something similar.
WS500 wiring example
