Good evening Thomas,
We checked, more asap can not be…
The market is limited at the moment.
You are going to cry…$$$.
To start with;
1 piece, SM0165-054-ATH Licap, 165F, 54V max.
You do not charge higher than 54V, correct?
To put over your batterij terminal.
Sorry, cheapest and most F for the $.
6 pieces, ALS70A334QS063, 0.33F, 63V,
Or better.
12 pieces, 0.27F, 63V, to cope more amps.
To put on your inverter terminals.
Why directly on the terminals.
Easy, 1 phase has load, others not.
Then it reacts directly for that phase (inverter) faster.
We say the market is limited, failure of bigger components availability at the moment.
So, we cannot make a CLC for your issue.
Of course we can, out of multiple smaller components, but to many $$.
And a huge impact on your busbar, space…
1 thing I can say that you might improve 45-50%.
This, as we do not know this chemistry of your battery completely.
My advise, show the above to the battery manufacturer.
Let’s see what they say and comment.
More input, better results.
@ Thomas, can you give a link what bat you exactly have.
So, we can analise the release of electricity better.
We know already partly from the test you did.
But, we do not know the full data, you see?
Just to understand, I’ve seen lead acid bats with 42 years of age and still working…
Yes, they lost capacity, 40-45% or so…but still!
Filtered air injection, catalyzers on top, drain to get the sludge out and filtered and recicled, you name it…
It’s all about cycles, less cycles, longer life…meaning a big battery.
Besides, bigger battery and thicker cables, less ripple, longer life.
No, over-or-under charging, less absorption, more float, longer lifetime.
Easy as it is, read the Victron book (energy unlimited) that’s a good book to start with.
We used it already in the beginning of the nineties or so, written only in Dutch at college, I remember.
Regards, Jeroen.
