It should get mapped correctly on start. The bluetooth library is in the package.
The dev has been looking at this but when spinning up the identical OS in a virtual environment it works perfectly.
This subject is split across two topics now, I will leave it to him to contribute as and when he is able.
Same here. I have the file listed in the squashfs-root directory as well from the extracted image.
So the package obviously doesn’t find it.
i am not a developer, but for me it sounds like an easy fix to tell the configuration where it can be found.
Correct! I did such Qt AppImages a lot and they worked fine regardless version installed in the system.
All, I have tried to clean this topic to make it more clear for the dev team.
Hopefully leaving the important bits.
Support has replied already.
They have installed the same Manjaro version i am using and cannot reproduce the issue.
Maybe it’s time for me to reinstall my device ![]()
Before that i am testing on a different device with lower hardware specs (my original one has > 64 GB RAM installed, sometimes this causes trouble).
As it’s not really important to get VC working on Linux as long as the Android App is working properly, the topic can be closed for now until the support has found something different.
Thanks for all of your support.
Uwe
I have pinged the broader team and pointed them here as well.
But yes, a reinstall might be a good test as well.
Could they try to install openSUSE TW as well? ![]()
You might need to ask the developers
I’ve also asked in Manjaro Community. At least one member confirmed the issues i have.
The issue doesn’t seem to be new:
It’s exactly my problem
The library is in the latest beta, that is a known issue 6.30 will fix but the beta isn’t working for you even though it is in the latest package hence why it works for the dev’s test environment on the same distribution.
Maybe i have to live with it.
As there is no guarantee that it will work after reinstall, i think i stick to the smartphone app.
At least the issue has now been found and can be recreated, so a fix will come along. ![]()
Thanks @nickdb for your support.
I think we should close this thread and continue in the other one where Thiemo is commenting, that should avoid having double work ![]()
