V3.70 grid setpoint not working
In the new 3.70 and 3.70~96 firmware the grid setpoint isn’t working.
Hard to report mistakes if treads are closed!
You are supposed to open new topics for newly discovered issues, or add to ones that are already opened for the same issue in the beta forum.
That process is clear in the main release notes.
but if they are closed I can’t report them!!!
Open.
A.
New.
Topic.
Only the release note subject is closed, where comments are not supposed to go.
If someone has reported already, add to that.
If that was closed as solved, then reference it in a new topic.
It is really not difficult.
And how can I find this already reported issue?
In the search you can’t find them!
In the relevant beta section just choose the “in this section” option of the search bar and type in what you are looking for.
Or, just scroll down a page or two. There aren’t that many topics for current betas.
Search works just fine.
If all else fails open a new topic. We will merge it if you have missed an obvious existing topic.
Sorry but in the beta section I can’t see this issue reported.
And thread 3.70~96 is closed.
The grid setpoint isn’t working 3.70~96, inverters do charge at full power and not the 8000W I adjusted.
And the latest 3.70 firmware doesn’t fix it.
Then open your own topic.
Report the issue clearly, when it started, if it works fine on prod versions.
Just noticed something!
If the SOC is under minimum SOC the inverters do charge at full power, is the SOC reached the inverters do charge at the wanted 8000W.
Is this intended behavior?
Is this behavior normal?
