I think this may have crept back in. Previously reported in v3.70~15. Could this be a node-red palette issue or version incompatibility?
I can read the relay state but unable to set any relay states.
Using node-red-contrib-victron 1.6.56
Confirmed the issue is still present with beta v3.70~78 maybe the switch control issue is with the latest version of the Victron palette for Node-Red?
I’ll retest when the latest Palette (pulished yesterday on Git/NPM) becomes available in my Signalk/Node-Red installation.
Solved with updated node-red palette victronenergy/node-red-contrib-victron 1.6.57 Thanks!
How did you update? I’m using a Cerbo GX mk2. From what I’ve found, “Only self installed extra nodes/pallettes are updateable.”
When you look at your list of palettes in node-red, you should see that the victron one can be updated. The catalogue is updated roughly every 24 hrs based on the updates pushed to NPM
