v3.64, I noticed the solar and alternator tiles change size when going from shore to inverting. Also I don’t see any animation during a slight discharge, but I do see it on shore power. Could be a serial battery interaction?
on shore
inverter only
on shore
inverter only
That resizing is normal, the tile size is dynamic. When shore is disconnected there is no info to display so the box is smaller. The others then fill the space. If your alternator was a WS500 that disappears when engine is off. The animations have some threshold before they start, no idea if they change with config so no specific answer to that one.
Thanks for the tile info, I hadn’t noticed that shift before. Alternator is dumb, but for an RV it would be nice to see the voltage & amperage, same with the DC loads, when we get back to v3.70
