V3.60~46 Still a bug at feed in limit settings
Similar but little bit different bug to the one in older betas (reported for ~20 and ~23).
You can now deactivate the feed-in limit, which is fine.
But when you activate it, it always displays as “active.” This also applies to the example here, with a 100,000W limit and 0W PV power at night.
Noted; will be checked - thank you.
