v3.50~13 Problems with KUS NKC42 Network Converter
Hi.
After the support for the KUS NKC42 Network Converter was implemented I have encountered some issues. I use this converter, but only one of the inputs. But the cerbo is picking up all 4 inputs. The result is that I get “dummy” sensors in in my overview and on my vrm dashboard.
If i delete the tank sensors, they reappear when I turn on power on the converter again.
Any chance of blocking these sensors in the UI?
Which version of the beta does this relate to or is it a general issue?
Please amend the title accordingly. Thanks
I think the support for the NKC42 was introduced with " v3.50~1 up to and including v3.50~5"
NMEA2000
  • Add support for tank senders with class 25 (Network) and function 132 (From analog). This adds support for the KUS NKC42 Network Converter.
Just confirming if you are on the latest build 3.50~13? If not, please test again.
Moved to the Venus OS beta sub-category.
Thanks for the report.
Yes I am on the latest beta.
Took a while to figure out. I thought it was some other device that as causing it to behave like that…
