Hey, after upgrading to version v3.50~13 the vrm portal does not longer show the critical loads total summary only the values for each phase.
Also the configuration menu for “Two way communication” switch is missing.
Portal id: e45f01687735
Any hints?
The best hint is to read the full change log for ~13 which explains the significant security changes which has affected various GX settings, doing away with some and adding others.
(Moving to venus os sub-category.)
