V 3.73 and nodered
I previously had afully work ing system with nodered. I wanted to change some of my nodered flows and came across issues.
When I connect to the console settings/general it states that I am running version 3.73 but at the top next to 'support status it says check items in orange, which is nodered, and I am asked to upgrade to version 3.73.
I have tried this numerous times, rebooted the inverter, but still i cannot get Nodered to work.
Any suggestions?
TIA,
Graham
That won’t help you, it is trying to reset the build.
You can go to the nodered section and choose reset, it will reinstall a vanilla instance.
Hi @nickdb ,
Thanks for the prompt reply.
one question will the ‘reset’ loose my current NodeRed flows?
Thanks,
Graham.
Yes, it removes and redeploys a blank installation, you need to reload your palette and import the flows, so a backup is important.
