Hi. I’m wondering if I can use the load output of an MPPT 100|20 on a 48 V nominal system to switch an Orion-TR 48|12-9 DC-DC converter on and off. I don’t see any voltage requirements for the remote switch in the manual for the Orion-TR 48|12-9. I’m measuring continuity between the (+) and (-) load terminals of the MPPT 100|20 when the load is on and measuring an open circuit on the load terminals of the MPPT 100|20 when the load is off.
Thanks for your reply. What I’m trying to do is have the DC/DC converter charge a 12 V battery from the 48V batterie bank when there is excess solar energy.
I can set the MPPT 100|20 to turn the load terminals on at say 54.0 volts. I’d like that to turn the Orion-TR 48|12-9 and am wondering if I need to use an external relay connected to the remote terminals on the Orion-TR 48|12-9 or if the remote terminals can be controlled directly from the load output of the MPPT 100|20. I’m curious to try it but don’t want to fry the TR 48|12-9 by connecting 54.0 volts to the remote terminals if they’re not designed for it.
I originally planned to power the input terminals on the TR 48|12-9 from the load terminals of the MPPT 100|20, but for some reason the output on the MPPT 100|20 load terminals is limited to 1A with a 48 V battery bank.
