anli
1
In Version 3.7 Garmin EmpirBus should be introduced. However, I can’t find it yet. Can anyone point me to that?
I wrote a own node for Garmin Empirbus. you can find it here: https://www.npmjs.com/package/node-red-contrib-garmin-empirbus
This is mainly written to use for integration with Alexa VoiceControl.
2MAS
(Thomas Nygaard Rask)
2
Hi anli
You must first create an Empirbus program where you add the outputs you want to control.
Empirbus and Victron must also be on the same network
after you have edited your Empirbus program you can see the desired outputs to your GX unit.
Thomas
