Username for password in local security profile
I did a MQTT connection from a Multi II to HomeAssistant.
For that I created on the HomeAssistant a /share/mosquitto/mosquitto.conf, which creates a MQTT briged to the MQTT broker of HomeAssistant:
persistence true
allow_anonymous true
connection victron
address 192.168.xxx.xxx:1883 # IP und Port des Victron-Brokers
#remote_username xxxx # Benutzername für Victron MQTT
#remote_password xxxx # Passwort für Victron MQTT
topic N/xxxx/# in 0 victron/ # Eingehende Topics von Victron, xxxx is ETH MAC adress
#topic R/xxxx/# out 0 victron/ # Ausgehende Topics zu Victron
#topic W/xxxx/# out 0 victron/ # Schreibzugriffe zu Victron
bridge_insecure true # Deaktiviert Zertifikatsprüfung (wichtig bei Victron)
A Node-RED flow creates the cyclic MQTT keepalive.
But I want to activate the authentification and security in the communication:
RemoteConsole/Settings/General/LocalNetworkSecurityProfile from unsecured to weak or secured.
Then I have to put a password.
The MQTT broker in HomeAssistand needs a username, if a password is required.
But I cannot find the username.
What is the username? Is it hardcoded in the Victron OS (v3.66)?
Thanks
Gerd
Have you tried root and your ssh root password?
Create a new user and password
Hello Fredd,
I have yet no root access.
This question is not about VRM access, but about local MQTT access.
The VRM access is possible via the MQTT Explorer.
Gerd
My username is admin. The password is what you already set
I think the username is not used.
If I activate a password, I can connect via MQTT Explorer, no matter which username I use.
So, I think, the implementation in HomeAssistant has got a problem !?
Gerd
Is this your complete mosquitto.conf?
Example my mosquitto config (Linux) and I see no listener
allow_anonymous false
password_file /etc/mosquitto/passwd
listener 1883 0.0.0.0
#message_size_limit 0
#message_size_limit 1000
log_dest file /var/log/mosquitto.log
log_type error
#log_type all
log_timestamp true
log_timestamp_format %Y-%m-%dT%H:%M:%S
Default on the MQTT server on your Cerbo GX
zero_byte_username_is_anonymous true
for security
I found it.
I had in the mosquitto.conf:
remote_username nomatters # comment
remote_password password # comment
But I could see in WireShark that both values were transfered to the victron MQTT with all caracters including the comments.
So I deleted all caracters after the username and password and the connection is established.
Gerd
