Upgraded to 3.71 lost relays
Does GUI-Mods work with 3.71? I have two relays, one controlled by a RuuviTag, to turn on the battery warmer when the temp drops to 5C The other to control a camera mounted on the comms tower. On update to 3.71. I lost both of them. The only thing left was the RuuviTag. I would like to run 3.71 as it offers some functionality that I do not see in 3.55.
Appears I was able to get it working, I went in and noted that the gui-mods code needed to be upgraded, but it would not allow me to do so. I backed out to rev 3.55 and regained control, i did the upgrades then re-installed 3.71. At which point I was able to observe and control the relays.
There was a bug in GuiMods that prevented the relay and digital inputs overviews from showing up for v3.7x firmware. This was fixed in GuiMods v11.2.
Yes, once I got your code updated after going back to 3.55, 3.71 looks good now. Sure would like to have switch to turn off the inverter/charger icon on my DC only systems. Causes a LOT of questions. Now I can see all of the relays on the HAT, thank you.
Well not home free yet, I was checking the cameras on our AREDN mesh network and the one where I did the 3.71 upgrade is off line. All of the firmware with GUI-MODS appears to be working but the relay is not pulling in when I turn it on. Any ideas? This also worries me as to the temperature controlled relay as it turns to battery heater on. Not real worried now as we are pretty much beyond that much cold and the battery box is well insulated so a code night will not come near dropping it down to critical.
Turned our the gpio_list was wiped out (even though it was in the /data) so I had to go in and redo it again. I left a good copy in the /data directory too.
The only issue I am having is when I reboot the RPi it will not re-connect to the network without a hard reboot.
