Upgrade to my remote site with Victron
Hello All,
I just started a Solar company, Focusing on both installations and monitoring/management systems. I would like to share my system which i use as a laboratory.
I run a remote lab site, about 2 hours from me, on an old 4 kWp system with a Lexron inverter and a 5 kWh 15S battery. The site draws about 1.7 kW on average and can peak near 3.5 kW during the day time when sun is up. This year I expanded the system with Victron equipment: 2.4 kWp of solar panels, a SmartSolar MPPT 150/35, a MultiPlus-II 48/5000/70-50, and a Pylontech UF5000 battery. The UF5000 is 16S and the old battery is 15S, so the two batteries cannot be connected in parallel.
I wanted to keep the old system in use to support the Victron setup, but I had three problems:
  1. The UF5000 (16S) and the old battery (15S) cannot be paralleled because their voltages differ.
  2. The Lexron inverter becomes unstable under high loads. The site is remote, so I had to ask a friend to reboot it each time.
  3. Neither the Lexron inverter nor the old battery has remote monitoring or management.
So Victron solved all my problems,
Here is my setup,
The Victron setup solved these problems. The Lexron output feeds the MultiPlus-II grid input through a Schneider Electric EZ9C32240 2Ɨ40 A contactor, which the CerboGX controls. The MultiPlus-II draws its minimum of 6 A (about 1.3 kW) from the Lexron, which keeps the Lexron running stably.
The old battery is measured with a SmartShunt 500A. I wrote a Node-RED flow that monitors its state of charge. When the level drops below 30%, the CerboGX Relay 1 opens the contactor to disconnect the Lexron.
I also installed a Raspberry Pi running Venus OS and connected a temperature sensor to measure the real-time internal temperature of the site. The Raspberry Pi publishes this data to AWS IoT Core over MQTT. I plan to control the fans through CerboGX Relay 2 once I have the fan control logic in place.
I built a dashboard that monitors all devices through VRM and shows the current hourly electricity prices for my region. Read-only access is available at https://demo.kanada.energy/ with user : demo@kanada.energy and the password : Demo1999!
I’m open to any suggestions.
