Unwanted, unused widget/graph
My installation includes the following:
Multiplus-II 48/5000/70-95 120V, v552
Cerbo-S GX, v3.54
SmartShunt 500A, v4.16
SmartSolar MPPT VE.can 250/85 rev2, v3.16
PV Array, 1260W, 4) 315W panels in series, Ground Mounted
16) 12.8V 100Ah Batteries, 4S4P, 20,480W
A/C Loadcenter 120V 60A
My system has been in service approximately 2 months.
There are 2 widgets/graphs labeled “To A/C input” and “From A/C input” that contain no information and appear to be unnecessary.
Due to my OCD, ADHD and anal retentive nature I’d like to remove them.
Furthermore I’m concerned that the selling dealer may have preprogrammed the inverter incorrectly.
It appears the widgets may be relayed to grid connectivity. I’m completely off grid as there is no commercial electricity available.
Of course I have contacted the dealer and they recommended that I long press the widget and select remove. Perhaps I have attempted this when viewing the installation from the wrong program or portal. In any event the long press yielded negative results.
I’m hopeful someone will view the attached screen shot and better understand the question and make a recommendation.
Thanks, Mike
it is not possible to alter the dashboard of the VRM. (the screen you have screen-shot of.)
you can in the advanced tab do what you like.
the dashboard is designed for many system types and many of them do have AC in and out.
