Yesterday my VRM App on my iPhone 14 lost its login for no apparent reason.
In attempting to log back in on my iPhone, I enter my email, a new window opens, a progress bar advances and disappears, but the page never loads. It remains empty and the log in process does not advance.
VRM on my desktop devices still works normally.
I use Brave as my browser and have since I’ve had the App. The issue does not change if I turn off Brave protections for victronenergy.com, so I don’t suspect Brave being the issue. I also swapped default browser to Safaris and the issue remained the same.
I can still access VRM through the web version on the phone.
I have deleted and reloaded the App and issue remained.
I have a very similar issue. I can use the web verson on the computer, no problem. Have been for 4yrs. I have also been using the app on the ph for 4yrs with no issues. Now when I try to use the app, it opends the new window as you said, but then it returns the msg “Invalid User Name”. I’ve deleted the app, re-loaded. Same thing. Tried multiple times in every wauy I can tink of. Is extremey frustrating as I use the app on the ph a lot more than the computer.
“I disabled the “shields” refreshed the page and could login again. Re-enabled the shields, logged out, and could login still … so I’m not sure what is blocking”
Thank you all. I finally did manage to log in today. Upgraded phone to OS27 in case that was a resolution. It was still the same.
But this time in the empty screen that came up there was something different. Possibly a new button in the margin. I don’t recall exactly what, but it now gave me the option to open the empty page in the browser. That opened the log in page and once I’d logged in and came back to VRM, it worked again. The original empty page was still open, so I just closed it and it still worked.
Phew. I feel whole again.
