Two MP in one site, one inverter only, second charger only
I expanded my existing system with one more MP by adding another MP and now it works with the first one being just an inverter and the second one being just a charger. How do I add a second inverter to the dashboard?
You can’t. This isn’t exactly a supported configuration.
The second system needs to be connected to the GX by a mk3 USB.
The restrictions for this are in the GX (Cerbo) manual.
You can generate widgets for the additional system but it will not appear on the console or dashboard.
Displayed natively no.
But you can add a shunt as a dc meter and have that display.on the interface.
Unless you are able to set up something custom with node red or other programming?
I created widgest, it shows OK, yes but it is not displayed on dashboard. So this is it?
Thanks
That’s it.
