Good day. May I ask if anyone has experience connecting two Victron 100A Buck-Boost DC-DC converters in parallel, using a single alternator, to increase the overall charging current?
Would appreciate any insights or recommendations. Thank you!
This can be done if you program each exactly the same…not one parameter different…this, as they do not see eachother and then to act at the same time…
OR, program them different, so that one switches off at low power available (low rpm motor), and the other still acts on a lower setpoint.
So, yes, you can set it up as you want in every case.
I like your input, 2 have redundancy, if one fails you have the second one to cover up.
So, our advice is to set them just so slightly apart that one is “master” and the second “slave”.
In that way the master takes the biggest “chunk” and the slave is following and therefore has a longer life, so, by switching settings once a year, both get the same age..
