Touchscreen MPI3508 with raspberry pi 2
I tried to install 3,5" screen with GPIO and HDMI interfaces using RpiDispalySetup but I only managed to make it work with HDMI (so no touch control). Tried everything possible solution I found around but non worked. Is there any solution to this issue? While trying different solutions I found that when I want to run ts_calibrate I get: ts_setup: No such file or directory. I am absolutely a newbie to this. Maybe it’s missing driver?
